Requirements missing for nodejs-2:8.17.0-1nodesource.x86_64
Setting up Linux (CentOS) workstation as a development environment
As per page 5/10 @ https://developer.cisco.com/learning/modules/dev-setup/dev-centos/step/5,
[qaswar@localhost ~]$ sudo yum install -y nodejs came up with the following error:
Node.js Packages for Enterprise Linux 8 - x86_6 250 kB/s |  77 kB     00:00
Error:
 Problem: cannot install the best candidate for the job
  - nothing provides python >= 2.6 needed by nodejs-2:8.17.0-1nodesource.x86_64
  - nothing provides /usr/bin/python needed by nodejs-2:8.17.0-1nodesource.x86_64
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
2 Accepted Solutions
****nothing with --nobest****
qaswar@localhost ~]$ sudo yum install -y nodejs --nobest
Last metadata expiration check: 0:04:11 ago on Tue 07 Jul 2020 10:19:50 PM PDT.
Error:
 Problem: conflicting requests
  - nothing provides python >= 2.6 needed by nodejs-2:8.16.1-1nodesource.x86_64
  - nothing provides /usr/bin/python needed by nodejs-2:8.16.1-1nodesource.x86_64
  - nothing provides python >= 2.6 needed by nodejs-2:8.16.2-1nodesource.x86_64
  - nothing provides /usr/bin/python needed by nodejs-2:8.16.2-1nodesource.x86_64
(try to add '--skip-broken' to skip uninstallable packages)
*****nothing to do with --skip-broken*****
[qaswar@localhost ~]$ sudo yum install -y nodejs --skip-broken
Last metadata expiration check: 0:04:41 ago on Tue 07 Jul 2020 10:19:50 PM PDT.
Dependencies resolved.
Nothing to do.
Complete!
If 'command not found' on 'node -V' do the following two lines
curl -sL https://rpm.nodesource.com/setup_12.x | sudo bash -
If 'node -V' show some old version and you can't get updated one do the following three lines
yum module disable -y nodejs
I got v12.18.2
Error:
Nothing to do.
Complete!
I got v12.18.2
Solution is underneath, clicked by mistake
