router required any license bundle for handling voip trafic
i have a cisco c2951 how do i check the voice capability ? does it required any license to handle voip traffic
tanvsult
You need to install the UC license for the voice support. When you issue the Show version command on the router, it will show you all the installed and active licenses on your device:
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
                        Current       Type                Next reboot
ipbase        ipbasek9      Permanent         ipbasek9
security      securityk9    Permanent         securityk9
uc               None              None               None
data           None              None                None
In My case I do not have the UC license Activated. You need to first have the license installed in order to activate it.
There are two ways of getting the license. One is by purchasing the license from Cisco and the other is by requesting for a free 60 day trial license. Once you have the license with you.. copy the license file to the flash of the router and then key in the command
2951#license install flash0:FHH1216P07R_20090528163510702.lic
The following link gives you more information:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
Hi tanvsult,
Thank you very much for your prompt response
Could you please go through the following details , the license installed is evolution or permanent  ?Is this enough ?
Technology Package License Information for Module:'c2951'
uc            uck9          Permanent     uck9
data          None          None          None
Hope you used the license key that you generated for the device that you have and not the one that I have pasted in the reply. the license will be generated based on your Product ID and the serial number.
So do not use any other license key.... Kindly go through the steps that have been given in the doc to generate the license.
The license that you have installed is the permanent one.
And you should be good to go.....
Don’t worry I haven’t used your license(hope it will not work with my device :) , its been activated by default
