Problem with Fabric Module 2 in Nexus 7010
Hi, I’ve got this problem with my N7K and 2 of the fabric module’s.  The front LED of the N7K is yellow/orange instead of green (it’s supposed to be green I believe).  Not sure what this relates to, hw issue, config issue or?
As you can see below, 2 of the fabric module are powered down.  Restarting the fab’s og restarting the N7K does not power up the fab module’s.
VDC-ADMIN# sh module
Mod  Ports  Module-Type                         Model              Status
4    12     10/40 Gbps Ethernet Module          N7K-F312FQ-25      ok
5    0      Supervisor Module-2                 N7K-SUP2E          active *
6    0      Supervisor Module-2                 N7K-SUP2E          ha-standby
7    12     10/40 Gbps Ethernet Module          N7K-F312FQ-25      ok
10   4      Network Analysis Module NAM-NX1     N7K-SM-NAM-K9      ok
Mod  Sw              Hw
4    6.2(6a)         1.0
5    6.2(6a)         6.0
6    6.2(6a)         6.0
7    6.2(6a)         1.0
10   6.2(6a)         1.0
Mod      Application Image Description    Application Image Version   Status
10       Application linecard image       6.0(1)                      ok
Mod  MAC-Address(es)                         Serial-Num
4    28-34-a2-ab-e1-dc to 28-34-a2-ab-e2-17  JAE181002NA
5    e4-c7-22-10-2f-4f to e4-c7-22-10-2f-61  JAF1748AFJR
6    e4-c7-22-0f-dd-13 to e4-c7-22-0f-dd-25  JAF1748AFKG
7    54-4a-00-ac-09-d8 to 54-4a-00-ac-0a-13  JAE181002PX
10   e4-c7-22-0f-95-e6 to e4-c7-22-0f-95-ef  JAF1801AABH
Mod  Online Diag Status
4    Pass
5    Pass
6    Pass
7    Pass
10   Pass
Xbar Ports  Module-Type                         Model              Status
1    0      Fabric Module 2                     N7K-C7010-FAB-2    ok
2    0      Fabric Module 2                     N7K-C7010-FAB-2    ok
3    0      Fabric Module 2                     N7K-C7010-FAB-2    ok
4    0      Fabric Module 2                     N7K-C7010-FAB-2    powered-dn
5    0      Fabric Module 2                     N7K-C7010-FAB-2    powered-dn
Xbar Power-Status  Reason
4    powered-dn     Reset (powered-down) because module does not boot
5    powered-dn     Reset (powered-down) because module does not boot
Xbar Sw              Hw
1    NA              1.5
2    NA              1.5
3    NA              1.5
Xbar MAC-Address(es)                         Serial-Num
1    NA                                      JAF1749AFAB
2    NA                                      JAF1749AFDF
3    NA                                      JAF1748AEQR
4    NA                                      JAF1746BEFB
5    NA                                      JAF1749AMCA
* this terminal session
VDC-ADMIN#
5 Replies 5
richbarb
This command might help you to know what happened.
#show environment power
Richard
Well, not much info from that command.
VDC-ADMIN# sh environment power
Power Supply:
Voltage: 50 Volts
Power                              Actual        Total
Supply    Model                    Output     Capacity    Status
                                 (Watts )     (Watts )
1        N7K-AC-6.0KW               800 W       6000 W     Ok
2        N7K-AC-6.0KW               641 W       6000 W     Ok
3        ------------                 0 W          0 W     Absent
                                  Actual        Power
Module    Model                     Draw    Allocated    Status
                                 (Watts )     (Watts )
4        N7K-F312FQ-25              289 W        340 W    Powered-Up
5        N7K-SUP2E                  128 W        265 W    Powered-Up
6        N7K-SUP2E                  128 W        265 W    Powered-Up
7        N7K-F312FQ-25              281 W        340 W    Powered-Up
10       N7K-SM-NAM-K9              333 W        750 W    Powered-Up
Xb1      N7K-C7010-FAB-2             39 W         80 W    Powered-Up
Xb2      N7K-C7010-FAB-2             39 W         80 W    Powered-Up
Xb3      N7K-C7010-FAB-2             44 W         80 W    Powered-Up
Xb4      N7K-C7010-FAB-2            N/A           80 W    Powered-Dn
Xb5      N7K-C7010-FAB-2            N/A           80 W    Powered-Dn
fan1     N7K-C7010-FAN-S            198 W        720 W    Powered-Up
fan2     N7K-C7010-FAN-S            198 W        720 W    Powered-Up
fan3     N7K-C7010-FAN-F             14 W        120 W    Powered-Up
fan4     N7K-C7010-FAN-F             14 W        120 W    Powered-Up
N/A - Per module power not available
Power Usage Summary:
Power Supply redundancy mode (configured)                PS-Redundant
Power Supply redundancy mode (operational)               PS-Redundant
Total Power Capacity (based on configured mode)               6000 W
Total Power of all Inputs (cumulative)                       12000 W
Total Power Output (actual draw)                              1441 W
Total Power Allocated (budget)                                4040 W
Total Power Available for additional modules                  1960 W
VDC-ADMIN#
Are you sure the switch hasn't been configured this way?
You can manually power down the fabics in order to minimise overall power by using the command poweroff xbar. See below:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/hw/nexus7000/installation/guide/n7k_hig_book/n7k_managing_sys_hw.html#wp1052265
The N7K is brand new, and the Fab mod.2 in slot 4 and 5 has been like this from the first start-up.  Below is output sh module fabric 4, and  attached logfile from the command no poweroff xbar 4
VDC-ADMIN# sh module fabric 4
Xbar Sw              Hw
4    NA                                      JAF1746BEFB
Chassis Ejector Support: Enabled
Ejector Status:
Left ejector CLOSE, Right ejector CLOSE, Module HW does support ejector based shutdown, Ejector policy enabled.
VDC-ADMIN#
Se attachment for output of no poweroff xbar 4.
Problem solved. Had to replace the N7K chassis.
