SFP required to connect 20 KM long fibre on N5K
there is one SM Fibre of 20 Km distance and which I want to connect on N5K-C5548UP model of switch , can any suggest which model of SFP should I use to connect this Single mode Fibre to my N5K switch . IOS of N5K switch is version 6.0(2)N2(1).
Rick1776
Level 5
Level 5
Here are the 10G SFP that are compatible with your switch.
SFP-10G-LR
SFP-10G-LR-S
Minimum NX-OS 5.0(3)N1(1B)
Unfortunately the max distance is 10KM.
Links for you to review.
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc505771689
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html
This 3rd party SFP says it can go 20KM but it's not a Cisco SFP. Not sure it's true.
https://www.flexoptix.net/en/sfp-plus-lr-transceiver-10-gigabit-stm64-sm-1310nm-20km-11db-ddm-dom.html?co8061=48648
I would call Cisco TAC to see what they suggest.
Are you running Dark Fiber between the switches. Also I'm assuming your refering to 10G not 1G
Cisco Nexus 5500 platform supports 10 Gigabit Ethernet SFP+ copper Twinax cables for short distances and SFP+ optics (10GBASE-SR,
10GBASE-LR, 10GBASE-ER, GLC-ZX-SM and Cisco Nexus 2000 Series Fabric Extender Transceiver [FET-10G]) for longer distances. SFP+ has
several advantages compared to other 10 Gigabit Ethernet connectivity options:
● Small 10 Gigabit Ethernet form factor
● Optical interoperability with XENPAK, X2, and XFP interface types
● Low power consumption
● Hot-swappable device
● Cisco Nexus 5500 platform products support 8-Gbps Fibre Channel-compatible SFP+ for native Fibre Channel connectivity options; 8-Gbps
Fibre Channel-compatible short-reach and 10-km long-reach SFP transceiver modules operate at 8/4/2 Gbps and are supported in the
8-Gbps-capable native Fibre Channel ports on expansion modules and unified ports
please check below link for more info:-
