07-01-2016 11:47 AM - edited 03-01-2019 08:18 AM
I have a customer using a Cisco collector, and they have noticed their N9Ks' host names are being cut off after 32 characters. I found several bug IDs that are similar to this issue but all are for older versions of OS, they are running 7.0(3)I1(1), 7.0(3)I1(1b) on these Chassis: N9K-C9372TX, N9K-C9332PQ, N9K-C9372PX.
Can someone indicate if a recent bug has been opened for this issue that I may have missed, or perhaps verify the configuration and validity of this issue? The vrf context management configuration seems to control the output based on the attached troubleshooting document.
Thank you,
Josh
02-08-2017 05:00 PM
Hi Josh,
Not sure if you're still running into this issue.
I have ran into a similar issue today and the solution that work me was to removed "ip domain-name". Please find the below outputs for more detail information. Thank you,
abcd-efgh-ijk-lm-nop-sw1(config)# hostname ?
WORD Enter switchname (Max Size 32)
abcd-efgh-ijk-lm-nop-sw1(config)# sh hostname
abcd-efgh-ijk-lm-nop-sw1.cisco.com
abcd-efgh-ijk-lm-nop-sw1(config)# no ip domain-name cisco.com
abcd-efgh-ijk-lm-nop-sw1(config)# show hostname
Duy
02-09-2017 06:33 AM
Hello Duy,
Thanks for the update, though I an no longer working with this customer, they preferred to leave the ip domain-name configuration in place. A new bug was opened for this issue and a previous bug for older code was updated to include the new OS version as well.
Josh
