Threaded rails kit for C220M4S?
paul.hornsby
My customer has a rack that requires nuts and screws for attaching rails kits.  The only 2 rails kit  options for the C220M4S are UCSC-RAILB-M4 (ball bearing) and UCSC-RAILF-M4 (friction).  They are both described as "tool-less".  Are either of these compatible with a threaded rack?  If not is there a conversion adaptation available or a different rail kit I can order?  Thank you,
Manish Gogna
Hi Paul,
Please check if this helps
https://www.server-racks.com/mounting-cisco-ucs-slide-rails-in-a-threaded-hole-rack.html
Manish
- Do rate helpful posts -
Manish Gogna
Hi Paul,
Manish
