Showing results forĀ
Search instead forĀ
Did you mean:Ā
UCS C240 M3 stuck on memory testing / configuration
dchira
I've been dealing with this C 240 M3 server stuck on "configuring and testing memory" and running out of options and inspiration I'd appreciate  some suggestions where to go next with troubleshooting process.
Currently I can only access the CIMC, and no major errors are shown. Running on only flash drive should this be an issue?
Thank you.
dchira
The issue was due to memory hardware errors.
I booted up the server with one memory card at the time and sorted out the defective ones.
