06-11-2018 09:56 AM
Hi everybody,
Please hepl me resolve this case.
We have DR distance from DC about 30km.
In DC, we have 2 Cisco Nexus 7K devices.
In DR, we have 2 Cisco Nexus 9K devices.
Between DC and DR, We have 2 DWDM connections.
Can you have a any solution to aggregate (vPC or any solution) 2 DWDM links ?
If you have solution, please give me configure example?
My topology is below,
Please help us, Thanks for your support
06-11-2018 11:11 AM - edited 12-22-2022 01:30 PM
You can use Back to Back VPC, see the following example:
https://www.netcraftsmen.com/configuring-back-to-back-vpcs-on-cisco-nexus-switches/
06-17-2018 12:48 AM
I would say it heavily depends on the requirements to the DR site and the switch models (line cards)? Are there a requirement for L2 between the sites or will L3 be just fine? I would always try go with L3 routing between sites to avoid L2 loops. If L2 is a requirement, then back-to-back VPC as Malik suggest will be a fine way to go.
/Anders
