UCS director
if i want to deploy ucs director , the license of the ucs director depend on what , the numbers of physical servers or virtual servers ?
5 Replies 5
Wes Austin
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-director/200218-UCS-Director-licensing-FAQ.html
What are the licenses that exist for UCS Director and what are they for?
These tables list the available licenses, and their use case.
Please note it is important to make a distinction between the Product ID (PID) you order, and the feature shown inside the license file. E.g. ordering a CUIC-SP-BASE-K9 license and activating the resulting PAK results in a CUIC-BASE-K9 license.
Evaluation Licenses
Product ID (PID) License Feature Description
EVAL-CUIC-BUN
EVAL-CUIC-BASE-K9
EVAL-CUIC-PHY-SERV EVAL-CUIC-PHY-STOR EVAL-CUIC-PHY-NETW EVAL-CUIC-PHY-OTH EVAL-CUIC-XPOD-S EVAL-CUIC-XPOD-M
Evaluation License bundle.
Can be ordered for free from this link.
Includes trial versions of the following, valid for 60 days:
1 UCS Director Base License,
100 Server Licenses (+2500 VM's),
30 Network Licenses,
30 Storage Licenses,
15 Other Licenses,
4 ExpressPod / FlexPod Express Small Licenses, and
4 ExpressPod / FlexPod Express Medium Licenses
Not-For-Resale Licenses
NFR-CUIC-BUN
NFR-CUIC-BASE-K9
NFR-CUIC-PHY-SERV
NFR-CUIC-PHY-STOR
NFR-CUIC-PHY-NETW NFR-CUIC-PHY-OTH
NFR-CUIC-XPOD-S
NFR-CUIC-XPOD-M
Not-For-Resale (NFR) license bundle for Cisco Channel Partners, for installation in their lab.
This license is bound by the terms and conditions of Cisco's channel partner NFR program.
Includes:
25 Server Licenses,
10 Network Licenses
10 Storage Licenses,
10 Other Licenses,
4 ExpressPod / FlexPod Express Medium Licenses.
Server-Based Licenses
Note: These licenses may also be available as part of a bundle offering, e.g. CUIC-SVR-OFFERS. Please check with your Cisco Partner/Reseller or Account team as offerings may vary over time.
CUIC-BASE-K9
CUIC-SP-BASE-K9
CUIC-BASE-K9
Base license, required for every installation of UCS Director (except when using the EVAL license). Installation of any other license requires a BASE license to be installed first.
In a HA (High Availability) scenario, both the Primary and Secondary instances each require a separate BASE license.
CUIC-PHY-SVR
CUIC-SP-PHY-SVR
CUIC-PHY-SVR-10
CUIC-PHY-SVR-50
CUIC-PHY-SVR-100
CUIC-PHY-SVR-250+
CUIC-PHY-SVR
This is a counted license, i.e. it can be bought for a certain amount of servers.
Each count entitles the use of one physical server (hypervisor host) running 50 server VM's or 250 desktop VM's, AND 1 network node AND 1 storage node.
CUIC-PHYSVRBM
CUIC-PHYSVRBM-10
CUIC-PHYSVRBM-50
CUIC-PHYSVRBM-100
CUIC-PHYSVRBM-250
CUIC-PHYSVRBM-500
CUIC-PHYSVRBM-1K+
CUIC-PHYSVRBM
Each count entitles the use of one bare metal server (i.e. a server running an operating system without hypervisor).
In addition, each 2 counts entitle the use of 1 network node and 1 storage node.
Example: a CUIC-PHYSVRBM-50 license will allow the use of 50 bare metal servers, 25 network nodes and 25 storage nodes.
CUIC-PHY-STOR
CUIC-PHY-STOR-11
CUIC-PHY-STOR-51
CUIC-PHY-STOR-101
CUIC-PHY-STOR-251+
CUIC-PHY-STORCounted license for storage systems.
CUIC-PHY-NETW
CUIC-PHY-NETW-11
CUIC-PHY-NETW-51
CUIC-PHY-NETW-101
CUIC-PHY-NETW-251+
CUIC-PHY-NETW
Counted license for network devices (including Cisco ASA Firewalls).
CUIC-PHY-OTHCUIC-PHY-OTH
Not yet used. May be required in the future when support for L4-L7 devices is added (e.g. load-balancers).
CUIC-POD-ENT
Enterprise Pod license bundle.
Includes:
4 Server Licenses
2 Network Licenses
2 Storage Licenses
Note: A BASE license is not included and should be acquired separately.
CUIC-XPOD-S
Expresspod small license bundle.
Includes:
25 Server Licenses (limited to UCS C-series servers)
6 Network Licenses (limited to Nexus1000v and Nexus3000)
2 Storage Licenses (limited to NetApp 2220)
CUIC-XPOD-M
Expresspod medium license bundle.
Includes:
75 Server Licenses (limited to UCS C-series servers)
2 Storage Licenses (limited to NetApp 2240)
CUIC-XPODS-UP
Upgrade from CUIC-XPOD-S to full license.
CUIC-XPODM-UP
Upgrade from CUIC-XPOD-M to full license.
Rick1776
Level 5
Level 5
As Wes noted below each device you want to participate in UCS director needs a license.
Does storage need spacific license ?
