Hello All,
I'm trying to configure pvlans over a vpc but the vpc seems to be down.
I've tried searching for documentation on pvlan & vpc interoperability but couldn't find anything so far.
Could anyone shed some light on this?
My outputs are as below.
P003# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 904
vPC+ switch id : 904
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
vPC fabricpath status : peer is reachable through fabricpath
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 1
Peer Gateway : Enabled
Peer gateway excluded VLANs : -
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
Fabricpath load balancing : Enabled
Port Channel Limit : limit to 244
vPC Peer-link status
id Port Status Active vlans
1 Po10 up 400-405,410-412,420-423,430-435,440-441,450-451,46
0-461,470,480-481,920-921,950-958,999,1040-1048,10
51,2400-2405,2410-2412,2420-2422,2430-2435,2440-24
41,2450-2451,2460-2461,2470,2480-2481,2950-2959
vPC status
id Port Status Consistency Reason Active vlans vPC+ Attribute
1040 Po1040 down* Not Consistency - DF: No, FP
Applicable Check Not MAC:
Performed 904.1.65535
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
-P003# show vpc consistency-parameters vpc 1040
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
STP Port Type 1 Edge Port Edge Port
STP Port Guard 1 Default Default
STP MST Simulate PVST 1 Default Default
Pvlan list 2 - (423,1051)
vPC+ Switch-id 1 904 904
vPC card type 1 Empty Empty
Allowed VLANs - 423 423
Local suspended VLANs
P003# show vlan private-vlan
Primary Secondary Type Ports
423 1051 isolated Po1040, Po1050, Eth4/30, Eth4/31
P003# show run int po1040
!Command: show running-config interface port-channel1040
!Time: Thu Mar 5 10:42:17 2015
version 6.2(2a)
description TEST PORTS FOR BACKUP PVLAN SERVER-LK
switchport mode private-vlan promiscuous
switchport private-vlan mapping 423 1051
vpc 1040
