03-21-2021 05:43 AM
03-21-2021 06:27 AM
Hello @Ibrahim Jamil
If you plan on using the Nexus switches as your gateway for the servers then YES, HSRP is needed. In fact, HSRP + VPC works better then without VPC, because in vPC scenario, regardless if the node is HSRP active or HSRP standby, both vPC peers are actively forwarding and routing the traffic.
Additional to enabling HSRP, there are few features related to vPC and routing:
If interested in routing over vPC, there is a list of supported typologies: https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/118997-technote-nexus-00.html
Stay safe,
Sergiu
03-21-2021 06:27 AM
Stay safe,
Sergiu
03-21-2021 09:26 AM
Hi Sergiu
thanks
very informative , i like the way y answer the thread
03-21-2021 10:13 AM
Happy to help! ^_^
03-21-2021 07:45 AM
yes you need it if you like nexus to be your Layer 3 Gateway or building some IGP peers or so on.
03-21-2021 09:27 AM
thanks bro balaji , the thread still open there pls when u have time look at it
03-23-2021 10:26 AM
Hi Ibrahim
Nexus like any other L3 multilayer SW or Router when we connect two through broadcast domain we need to config HSRP.
the Q is what is different between Nexus and other L3 SW HSRP?
the Answer is in normal HSRP the one peer work as active and other work as standby and the active one is forward traffic send to VIP of HSRP group
in Nexus HSRP the both peer work as active and hence and forward traffic send to VIP of HSRP group.
this make HSRP in Nexus Active/Active.
why we need HSRP simply we have two L3 and we need One default GW in PC so we use HSRP to generate one IP which is VIP of HSRP and this VIP will be the only default GW for all PC.
