01-09-2018 12:18 PM - edited 03-01-2019 08:42 AM
I have this X2-10GB-SR on a cigesm switch port Te is used as uplink yet i now see the X2-10GB-SR LED status as amber and the port goes to err-disable. Is the X2-10GB-SR faulty?
Nyi
01-09-2018 12:22 PM
Its possible. Have you swapped it with a known working X2? What was the outcome?
If this worked before and now does not, I would suspect it could be hardware. If this is a new setup, I suspect it could be config related issue.
01-09-2018 01:04 PM
