XML API issue with CIMC (v3.0)
knoppgary
I have 2 UCS C240 M4SX servers. They are each running a different CIMC version.   Although they both have XML API enabled, I'm unable to login into the server with the later CIMC version v3.0(3a).     Below is a simple script showing what happens.    I have tried later versions of python too.    Any idea whats happening and how to solve?
1) sdot-c240-0041   v2.0(10b)
2) sdot-c240-0061   v3.0(3a)
## Python script
#!/usr/software/bin/python2.7.5
import requests
requests.packages.urllib3.disable_warnings()
for server in ["sdot-c240-0041-cimc", "sdot-c240-0061-cimc"]:
    print(server + ":")
    url_api = "https://" + server + "/nuova"
    data = "<aaaLogin inName='admin' inPassword='password'></aaaLogin>"
    r = requests.post(url_api,data=data,verify=False)
    print("STATUS: " + str(r.status_code))
    print(r.headers)
    print(r.text)
## RESULTS
> ./p1.py
sdot-c240-0041-cimc:
STATUS: 200
{'Content-length': '187', 'Keep-Alive': 'timeout=60, max=2000', 'Server': 'Mbedthis-Appweb/2.4.2', 'Connection': 'keep-alive', 'Date': 'Fri, 12 Jan 2018 18:52:35 GMT', 'X-Frame-Options': 'SAMEORIGIN', 'Content-type': 'application/soap+xml;charset=UTF-8'}
<aaaLogin cookie="" response="yes" outCookie="1515783155/723d0d81-6299-1299-801a-720c6fc63d84" outRefreshPeriod="600" outPriv="admin" outSessionId="45" outVersion="2.0(10b)"> </aaaLogin>
sdot-c240-0061-cimc:
STATUS: 400
{'Date': 'Fri, 12 Jan 2018 11:53:12 GMT', 'Content-Length': '0', 'Server': 'Monkey'}
jomcdono
Hi Gary,
The 3.0 firmware version http process that is listening for XML API requests requires that 'Content-Type' be specified in the header of the http request
This code should work for you on the 3.0 firmware, it may work on the 2.x as well.  Hope this helps.
John
## Python script
import requests
    print(server + ":")
    headers = {'Content-Type':'application/xml'}
    r = requests.post(url_api,data=data,verify=False,headers=headers)
    print(r.headers)
    print(r.text)
jomcdono
Hi Gary,
John
## Python script
import requests
    print(server + ":")
    print(r.headers)
    print(r.text)
