16 port network module configuration
csross
I am getting the 16 port network module for a 3640. I want to create separate networks (vlans) and route between on the switch ports. Does anyone know how to accomplish this? The documents do not specify?
I assume you are talking about the NM-16ESW ? You can just create your VLAN interfaces and assign the switchports on the module to the respective VLANs. Let´s say you want to create VLAN 10, 20, and 30, this is what the configuration would look like (the IP addresses in this example are just examples, obviously):
interface VLAN 10
ip address 192.168.10.1 255.255.255.0
interface VLAN 20
ip address 192.168.20.1 255.255.255.0
interface VLAN 30
ip address 192.168.30.1 255.255.255.0
interface FastEthernet0/1
switchport mode access
switchport access vlan 10
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport access vlan 30
and so on...
HTH,
Georg
Thanks. My Ethernet interface on the 3640 will connect to a cablevision router and get its address via dhcp. The 3640 will be giving address via dhcp to a 10 network which will be one of the vlans. It will also be using NAT to gain public network access for that network. Do you believe in this config I can do that? One last thing, do you believe it will be slow since the routing doesn't take place in the module but the router?
thanks so much
