09-06-2002 05:10 PM - edited 03-02-2019 01:11 AM
PROBLEM:
I am trying to get my 1721 router and my PIX 515 to work together, and im not sure what is holding me back.
DETALS:
-Ive got the outside interface of the pix connected to the inside interface of the router with a crossover cable.
-Ive got the outside interface of the router connected to the T1 and can use the router as my default gateway to sucessfully get to the internet without the pix in between, once the pix is in place between the router and my host, and i change the default gateway on the host to the pix, NO work.
-Ping from inside network to pix inside interface YES works.
-Ping from inside network to router inside interface NO work.
-Ping from host using PIX as default gateway to a working outside IP NO work, but can see the icmp on the pix sending it to the router.
-Ping from outside host to inside IP's work, but i do not see the icmp on the pix debug screen like i should, i think the router is responding.
Here are the configs for both the router and the pix in that order, please help!
--1721 ROUTER CONFIG--
Current configuration : 1087 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname PacBellRouter
enable secret 5 XXXXXXXX
enable password XXXX
ip subnet-zero
ip name-server 206.13.28.12
ip name-server 206.13.31.12
modemcap entry line
interface FastEthernet0
description TO LOCAL LAN
ip address 192.168.100.2 255.255.255.0
ip nat inside
speed auto
interface Serial0
description PB CKT 40HCGS991156_OO1PT
ip address 64.160.180.38 255.255.255.240
ip nat outside
encapsulation ppp
no fair-queue
service-module t1 timeslots 1-24
ip nat pool webaccess 209.76.153.161 209.76.153.174 netmask 255.255.255.240
ip nat inside source list 1 pool webaccess
ip classless
ip route 0.0.0.0 0.0.0.0 64.160.180.37
no ip http server
access-list 1 permit 192.168.100.0 0.0.0.255
line con 0
password cnsc1
line aux 0
exec-timeout 300 0
password XXXXXX
login
modem InOut
flowcontrol hardware
line vty 0
password XXXXXXX
login
line vty 1 4
password XXXXXX
login
no scheduler allocate
end
---PIX 515 CONFIG---
PIX Version 4.4(7)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password XXX encrypted
passwd XXXXX encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
logging on
no logging timestamp
no logging console
no logging monitor
logging buffered debugging
no logging trap
logging facility 20
logging queue 512
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside 192.168.100.4 255.255.255.0
ip address inside 192.168.100.3 255.255.255.0
arp timeout 14400
global (outside) 1 209.76.153.162 netmask 255.255.255.240
global (outside) 1 209.76.153.163-209.76.153.174 netmask 255.255.255.240
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
conduit permit icmp any any
no rip outside passive
no rip outside default
no rip inside passive
no rip inside default
route outside 0.0.0.0 0.0.0.0 192.168.100.2 0
timeout xlate 3:00:00 conn 1:00:00 half-closed 0:10:00 udp 0:02:00
timeout rpc 0:10:00 h323 0:05:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
telnet 192.168.100.30 255.255.255.0
telnet timeout 5
terminal width 80
Cryptochecksum:XXXXXX
pixfirewall#
09-07-2002 01:12 AM
First of all, your IP address on inside/outside interface of PIX is wrong. You cannot have same subnet on both these interfaces, they have to be different subnets.
Secondly, bcz your router does not have a static route back for 209.76.153.0 network pointing back to your pix, since you are NATing on PIX.
Your PIX config is wrong. I am forwarding you these basic PIX URL which will help you setup your PIX;
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/config/bafwcfg.htm#xtocid17
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_62/config/index.htm
R/Yusuf
09-07-2002 12:02 PM
Unless there is a specific reason why you need NAT on the 17xx router, I would not use nat there. I would let the PIX handle the NAT function and overload NAT on the outside interface of the PIX.
As pointed out in the previous response, you need to have different subnets on your inside and outside PIX interfaces. Typically what I do is assign my "available LAN addresses" from my provider to the ethernet interface of the router, and the ouside interface of the PIX (one address each). Let the PIX perform NAT. Point a static default route from the PIX to the IP address on the ethernet point of the router. You won't need a route to the 209 subnet on the 1720 because it is locally attached on FE0. All traffic coming from the firewall to the router already has a source of 209.x.x.x because of NAT on the firewall. The only static route needed on the 1700 is a default to the PACBELL Internet router.
Good Luck
09-09-2002 03:29 PM
Everythings working now. thank you a bunch for your detailed answer. Im wondering how i can refine my setups i would like to remove any unnecessary commands from both the router and firewall. can you point out stuff to remove? thanks again!
---- 1721 Router setup ------
PacBellRouter#show config
Using 671 out of 29688 bytes
version 12.2
enable secret 5 xxXXXxxXXX.
ip subnet-zero
modemcap entry line
ip address 209.76.153.162 255.255.255.240
speed auto
interface Serial0
encapsulation ppp
no fair-queue
no ip classless
no ip http server
line con 0
password XXXXX
line aux 0
exec-timeout 300 0
line vty 0 4
no login
end
PacBellRouter#
---- PIX SETUP --------
pixfirewall# show config
: Saved
PIX Version 4.4(7)
enable password XXXXXXX encrypted
passwd XXXXXXXX encrypted
names
pager lines 24
logging on
no logging console
no logging monitor
no logging trap
logging facility 20
logging queue 512
mtu outside 1500
mtu inside 1500
ip address outside 209.76.153.163 255.255.255.240
ip address inside 192.168.100.2 255.255.255.0
arp timeout 14400
global (outside) 1 209.76.153.164 netmask 255.255.255.240
global (outside) 1 209.76.153.165-209.76.153.166 netmask 255.255.255.240
route outside 0.0.0.0 0.0.0.0 209.76.153.162 0
telnet timeout 5
terminal width 80
Cryptochecksum:f6745a2108ae0e91dfb90083f4dcfa54
pixfirewall#
