12-28-2004 12:41 AM - edited 03-02-2019 08:47 PM
Good day.
I'm trying to help a friend who lives abroad so I don't have the hands on the hardware.
He wanted to use a old 1600 series router as a firewall in a LAN.
So the test setup is as follow:
-a d-link router for internet connectivity. It has a 4 ports switch integrated
-a 1600 router
-a few PCs
The PCs and the 1600 is linked to the d-link built-in switch with the following IP schema:
d-link -> 192.168.1.1
1600 -> 192.168.1.10
1600 -> 192.168.2.1 (secondary)
pcz -> 192.168.2.22 gw -> 192.168.2.1
Of course, I told him to add a route to the d-link for 192.168.0.0 through 192.168.1.1 and to set the default gateways properly.
So the problem is he can, from the 1600 router, ping anything, inbound, outbound... all works; but when he pings from a pc, nothing works.
Debugging icmps he discovered that:
00:07:59: ICMP: redirect rcvd from 192.168.1.1 -- for 212.216.112.112 use gw 224.39.4.246
Any suggestions?
Thanks a lot
12-28-2004 01:39 AM
I assume the PCs and the router are connected to the D-Link ? Can you try and connect the PCs to the D-Link and assign an IP address in the range 192.168.1.0 with a default gateway of 192.168.1.1 to the PCs ?
In this case you would not really need the router...
My apologies if I am misreading your physical setup...
GP
12-28-2004 02:00 AM
In fact I know that I do not need the 1600 router for connectivity. My friend just wanted to use IOS features for firewalling purposes, turning the 1600 into a gateway
12-28-2004 02:18 AM
I am not sure this works with only one Ethernet interface and secondary addressing. I think you need two Ethernet interfaces (e.g. the 1605 has two) for the router to function as a gateway...
GP
