2507 Ethernet Interface ?
Yami
I have a 2507 router with 2 serial, 1 con, 1 aux and 16 ethernet hub ports. Which port should I use to set up an ethernet 0 interface and what command allows me to do so. It seems that I may have to use one of the ether hub ports as the actual ethernet 0 routable interface. How can I do this ?
Yami
rsissons
Level 5
Level 5
All the ethernet hub ports on the 2507 are exactly the same so it does not matter which one you pick.
That's cool, but how can I actully use the ethernet? I don't know what needs to be done or what commands to use. Thanks for the reply.
-Yami
