2511 Dialup help - Client connectivity
utawakevou
Level 4
Level 4
I have two cisco 2511 router(will change soon to 3660 router) for our dialup services. We are using Radius. All Our users who dialin using
Windows NT or 2000 or XP have to have SHOW TERMINAL WINDOW enable so that dialup users can establish an exec
connection where they will have to input their usernames and passwords. Our users who uses Win 95 or 98 will
have to run a script to get connected.
I dont want this as most of our users using our dialup services are using Win NT or 2000 or XP. Enabling that
SHOW TERMINAL WINDOW is quite complicated for them. What I want is for the users to get through when they first
enter their usernames and password on that dialup window.
Below is my current config:
SuvaDialUpRouter02#sho conf
Using 2271 out of 32762 bytes
version 11.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname SuvaDialUpRouter02
aaa new-model
aaa authentication login use-radius radius local
aaa authentication ppp use-radius if-needed radius local
aaa authorization exec radius local if-authenticated
aaa authorization network radius local if-authenticated
enable secret 5 $1$bqWV$wMaKBOd6n4jimQWbzn.g0.
enable password 7 045802150C2E
username test password 7 120D000406
async-bootp dns-server 10.1.85.156
async-bootp nbns-server 10.1.85.156
chat-script cisco-default ABORT ERROR "" "AT Z" OK "ATDT \T" TIMEOUT 30 \c CONNc
interface Ethernet0
ip address 10.1.85.3 255.255.255.0
no mop enabled
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
interface Group-Async1
ip unnumbered Ethernet0
encapsulation ppp
no ip route-cache
no ip mroute-cache
keepalive 10
async dynamic address
async mode interactive
peer default ip address pool dialin
ppp reliable-link
ppp authentication chap use-radius
group-range 1 16
ip local pool dialin 10.1.86.65 10.1.86.80
ip default-gateway 10.1.85.22
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.85.22
radius-server host 10.1.85.156 auth-port 1645 acct-port 1646
radius-server key RoLalabalavu29
line con 0
line 1 16
autobaud
autoselect during-login
script dialer cisco-default
login authentication use-radius
modem InOut
transport input all
flowcontrol hardware
line aux 0
line vty 0 4
password 7 15181E1F102E242D3C
end
Please Help
regards
8 Replies 8
tepatel
Just configure "autoselect ppp" command under the line 1 16 config..That will serve both the purpose.
mljohnson
Level 4
Level 4
Do you purposely want the users to get an exec session? Or are they all PPP users? If they are all PPP users, you should be able to add either "autoselect ppp" under the line, or "async mode dedicated" under the interface, and all users will be logged into a PPP session using their dialup window info.
No, I dont want users to get an exec session. I have add that command.
I got this error message when I try to dial in from a Win 2K pc.
"Error 691:Access was denied because the username and/or password was invalid on the Domain "
Did debug Radius and got this result:
16w6d: RADIUS: Received from id 227 10.1.85.156:1645, Access-Reject, len 20
16w6d: %LINK-5-CHANGED: Interface Async15, changed state to reset
16w6d: %LINK-3-UPDOWN: Interface Async15, changed state to down
16w6d: RADIUS: Initial Transmit id 228 10.1.85.156:1645, Access-Request, len 83
16w6d: Attribute 4 6 0A015503
16w6d: Attribute 5 6 0000000F
16w6d: Attribute 61 6 00000000
16w6d: Attribute 1 12 75746177
16w6d: Attribute 30 2 03130379
16w6d: Attribute 3 19 03799D11
16w6d: Attribute 6 6 00000002
16w6d: Attribute 7 6 00000001
Im absolutely sure that Im inputting the right username and password.
Try removing the "if-needed" option under AAA, then capture the entire output of "debug ppp auth", "debug aaa authen", and "debug radius".
OK this is what I did. I remove the if-needed part, enter async mode dedicated to the Int Group-async 1
and enter auto select ppp on line 1 16
Debug aaa athen, ppp authen, radius.
When I dial in, manage to connect but when it comes to verify username and password, that is
where it gets disconnected and redial. Error message "remote computer is not responding"
There was no debug output on my screen. Even though I turn terminal monitor on.
Could it be my Radius Server allowing only exec connection?
Or could be some settings dialup properties of the clients ?
Anyway here is the configuration I did change
Using 2275 out of 32762 bytes
version 11.3
aaa new-model
aaa authentication ppp use-radius radius local
username usaia password 7 104D011C061C1B1F03113E
username alfred password 7 00171614125208031C70
username imm password 7 141E1F060503382A30213C3B
username localgovt password 7 0507090C204049060F11
username maff password 7 110418031143595F
ip domain-list govnet.gov.fj
ip domain-list itc.gov.fj
ip name-server 10.1.85.156
ip name-server 10.1.85.158
interface Ethernet0
no mop enabled
interface Serial0
no ip address
no ip mroute-cache
shutdown
interface Serial1
no ip address
shutdown
encapsulation ppp
no ip route-cache
no ip mroute-cache
keepalive 10
ppp reliable-link
group-range 1 16
ip classless
banner motd ^Cc
Welcome to ITC Services
Access to this Service is RESTRICTED to Authorised Government Users
Only.
Please direct any queries to the HELPDESK on Phone 306005
Use by Unauthorised persons is prohibited
^C
line con 0
line 1 16
autobaud
autoselect ppp
modem InOut
transport input all
line aux 0
line vty 0 4
end
It's hard to say what is happening without the debug. If you can't see if on your screen, try "clear log", enable the debug, run a test, disable the debug, and then "Show log". You may also want to increase your logging buffer with the config command "logging buffer". Check the RADIUS profile, too, to see that it allows who/what you want.
OK this is the debug result I got when I DONT put autoselect ppp on line 1 16 or async mode dedicated on int group-async 1. In other words making an exec connection.
17w1d: AAA/AUTHEN: create_user (0x1A2648) user='' ruser='' port='tty15' rem_add1
17w1d: AAA/AUTHEN/START (1302562061): port='tty15' list='use-radius' action=LOGN
17w1d: AAA/AUTHEN/START (1302562061): found list use-radius
17w1d: AAA/AUTHEN/START (1302562061): Method=RADIUS
17w1d: AAA/AUTHEN (1302562061): status = GETUSER
17w1d: AAA/AUTHEN/CONT (1302562061): continue_login (user='(undef)')
17w1d: AAA/AUTHEN (1302562061): Method=RADIUS
17w1d: AAA/AUTHEN/CONT (1302562061): continue_login (user='')
17w1d: AAA/AUTHEN (1302562061): status = GETPASS
17w1d: AAA/AUTHEN/CONT (1302562061): continue_login (user='utawakevou')
17w1d: RADIUS: Using stdio port information: port 15
17w1d: RADIUS: Initial Transmit id 17 10.1.85.156:1645, Access-Request, len 70
17w1d: Attribute 4 6 0A015503
17w1d: Attribute 5 6 0000000F
17w1d: Attribute 61 6 00000000
17w1d: Attribute 1 12 75746177
17w1d: Attribute 30 2 0212FFCB
17w1d: Attribute 2 18 FFCB5B93
17w1d: RADIUS: Received from id 17 10.1.85.156:1645, Access-Accept, len 38
17w1d: Attribute 7 6 00000001
17w1d: Attribute 10 6 00000001
17w1d: Attribute 6 6 00000002
17w1d: RADIUS: saved authorization data for user 1A2648 at 1A26E0
17w1d: AAA/AUTHEN (1302562061): status = PASS
17w1d: RADIUS: Constructed "ppp negotiate"
17w1d: %LINK-3-UPDOWN: Interface Async15, changed state to up
17w1d: As15 PPP: Treating connection as a dedicated line
17w1d: AAA/AUTHEN: dup_user (0x1BD6B8) user='utawakevou' ruser='' port='tty15' '
17w1d: AAA/AUTHEN: free_user (0x1A2648) user='utawakevou' ruser='' port='tty15'1
17w1d: AAA/AUTHEN: Method=IF-NEEDED: no authentication needed. user='utawakevou'
17w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async15, changed state tp
When I put in autoselect ppp or async mode dedicated and ON debug and diaI in without enabling "show terminal window" at the PC end I dont get any result of the debug on my window.
Ignore my last sentence of my last post. I did enable async mode dedicated on the int group-async 1 and try to connect without "start terminal window"
Below is the debug result
SuvaDialUpRouter02#
17w1d: As15 PPP: Phase is AUTHENTICATING, by this end
17w1d: As15 CHAP: O CHALLENGE id 5 len 39 from "SuvaDialUpRouter02"
17w1d: As15 CHAP: I RESPONSE id 5 len 31 from "utawakevou"
17w1d: AAA/AUTHEN: create_user (0x1BD6E4) user='utawakevou' ruser='' port='Asyn1
17w1d: AAA/AUTHEN/START (3021666351): port='Async15' list='use-radius' action=LP
17w1d: AAA/AUTHEN/START (3021666351): found list use-radius
17w1d: AAA/AUTHEN (3021666351): status = UNKNOWN
17w1d: AAA/AUTHEN/START (3021666351): Method=RADIUS
17w1d: RADIUS: Initial Transmit id 18 10.1.85.156:1645, Access-Request, len 83
17w1d: Attribute 30 2 03130529
17w1d: Attribute 3 19 05299A8E
17w1d: RADIUS: Received from id 18 10.1.85.156:1645, Access-Reject, len 20
17w1d: AAA/AUTHEN (3021666351): status = FAIL
17w1d: As15 CHAP: Unable to validate Response. Username utawakevou: Authenticae
17w1d: As15 CHAP: O FAILURE id 5 len 26 msg is "Authentication failure"
17w1d: AAA/AUTHEN: free_user (0x1BD6E4) user='utawakevou' ruser='' port='Async11
17w1d: %LINK-5-CHANGED: Interface Async15, changed state to reset
17w1d: %LINK-3-UPDOWN: Interface Async15, changed state to down
