2611 bandwidth control problem
huanghe
Network Diagram
internet------s0-[2611]-e0------LAN
Leased line 1Mbps to Internet,i try to distribute bandwidth to
different application.example,ftp can use max 400Kbps.
yesterday,i try to use Class-Based Weighted Fair Queueing
do it ,but it only attach a service policy to the output interface
so,how can i control bandwidth to the 2611 input serial interface?
thanks.
rsissons
Level 5
Level 5
Custom queuing is the best way to restrict bandwidth for certain protocols. See the following URL for more information -
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt2/qcfcq.htm
ahvn
You can use CAR for this.
access-list 120 tcp permit any any eq ftp
rate-limit input access-group 120 400000 50000 50000
This will do the needfull
Homin
aybra
You can't control input trafic because it depond from the remote router and not from your's so you can only distribute out put trafic
TX
