2801 with a 9 port Ethernet HWIC
markcole
have a 2801 with a 9 port Ethernet HWIC and a 4 port Ethernet HWIC. If you plug a machine into the switch modules, the machine will not pick up a dhcp address. If you put a static address on the machine, you can not ping the default gateway. You can ping another machine that is plugged into either the 9 port or 4 port modules. If you plug a cable into fa0/0 and the other end into the switch module, it still does not work. It is like the switch modules want to stay in their own little world.
any one any ideas how i manage to get devices plugged into the module switch ports to see the outside past the module
cheers for any info
spremkumar
Level 9
Level 9
hi
Can you give some lead on how the configuration is done ? have you configured any SVI and have ip assigned to that interface ?if thats the case have you made all these ports as a member of that vlan ?
if possible do post your configs here with both your public ips and passwords masked ..
regs
hostname **********
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret ********************
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 1:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 10.14.60.129
ip dhcp excluded-address 10.14.60.161
ip dhcp pool VOICE
network 10.14.60.160 255.255.255.224
default-router 10.14.60.161
option 150 ip 10.18.1.11
dns-server 10.17.1.23 10.17.1.64
ip dhcp pool DATA
network 10.14.60.128 255.255.255.224
default-router 10.14.60.129
ip host ccm1 **********
ip host ccm2 **********
ip multicast-routing
ip rcmd rcp-enable
voice-card 0
dsp services dspfarm
voice call convert-discpi-to-prog
interface FastEthernet0/0
no ip address
ip pim sparse-mode
speed 100
full-duplex
interface FastEthernet0/0.128
description DATA VLAN
encapsulation dot1Q 128
ip address 10.14.60.129 255.255.255.224
interface FastEthernet0/0.160
description VOICE VLAN
encapsulation dot1Q 160
ip address 10.14.60.161 255.255.255.224
interface FastEthernet0/1
ip address 10.14.200.18 255.255.255.252
duplex auto
speed 10
interface FastEthernet0/1/0
switchport trunk native vlan 128
switchport mode trunk
switchport voice vlan 160
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
switchport access vlan 128
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport stacking-partner interface FastEthernet0/3/0
switchport stacking-partner interface FastEthernet0/1/8
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface ATM0/2/0
no ip address
atm vc-per-vp 128
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Vlan1
no ip address
interface Dialer1
ip address ****************
ip pim sparse-mode
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ********************
ppp chap password ********************
ppp pap sent-username ****************
ppp ipcp dns request
hold-queue 224 in
ip classless
ip route 10.17.0.0 255.255.0.0 Dialer1
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
As this is a switching module you must also configure the vlan database, either through the (deprecated "vlan dat" command or via the IOS config)
Your switched vlan ports might be down otherwise.
The problem may also lie in the switchport mode trunk command that you have put on all ports. With the latest software you should configure the ports in access mode with an additional switchport voice vlan command.
The netto result of that is that it works as desired. I have not found any docs on the deeper issues behind this (may be something with autonegotiation) but in practice, it worked with me.
Leo
multiple Ethernet Switch HWICs installed in a host router will not act independently of each other. You need to configure stacking for both modules, as they will not work at all otherwise.
Stacking is the connection of two switch modules resident in the same chassis so that they behave as a single switch. When a chassis is populated with two switch modules, the user must configure both of them to operate in stacked mode. This is done by selecting one port from each switch module and configuring it to be a stacking partner. The user must then connect with a cable the stacking partners from each switch module to physically stack the switch modules. Any one port in a switch module can be designated as the stacking partner for that switch module.
Beginning in privileged EXEC mode, follow these steps to configure a pair of ports on two different switch modules as stacking partners.
COMMAND SUMMARY STEPS
1. interface fastethernet interface-id
2. no shutdown
3. switchport stacking-partner interface FastEthernet partner-interface-id
4. exit
5. interface fastethernet partner-interface-id
6. no shutdown
7. end
Nethelper
