3550 - policing on physical interface
vgloser
Could anyone help me with the conf of policing on 3550 physical port (FE)? What I want to do is to do a basic rate-limiting on the FE port (ex. 1 Mbps). I have configured it:
policy-map POL_MAP1
class class-default
police 8000 8000 exceed-action drop
and attached to the int. However, it dos not work.
seilsz
Level 4
Level 4
Vaclav,
Can you post the output from 'sh mls qos interface'?
~Zach
It is a bit strange. How could has the switch dropped packets if it did not classify them first?
LAB-1C35#sh mls qos interface fastEthernet 0/5 statistics
FastEthernet0/5
Ingress
dscp: incoming no_change classified policed dropped (in bytes)
Others: 398444426 398444426 0 0 5988588
Egress
Others: 1105968934 n/a n/a 0 0
