3560 GBIC Issue
dlumsden
Has anyone else had problems with 3560 GBIC modules?
When using 3560's with QOS enabled and a GBIC module acting as a trunk (GLC-T or GLC-SX) certain applications open files very slow.
If I disable QOS or use one of the fast ethernet ports as a trunk the problem goes away.
Prashanth Krishnappa
We had seen issues due to which non QoS traffic could get affected due to the way buffers are carved after enabling QoS on 3560/3750. Try making the following changes to queues and see if it makes any difference
mls qos queue-set output 1 threshold 2 400 400 100 400
mls qos queue-set output 1 buffers 15 45 20 20
I tried this after reading a response to a previous message, but it has no effect.
Any other ideas?
