3560 mls qos interface statistics output
Aaron Harrison
I've seen questions like this before, but never seen a satisfactory answer... I can't find any good documentation anywhere about this command.
If you run it, you get tabular output of some statistics - with no headers to the columns.
The closest thing I've found to it is in this document:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12113ea1/3550cr/cli2.htm#wp2418191
It shows the fields as: Incoming, No_Change, Classified, Policed and dropped.
I have a switch with a modified cos-dscp map so that cos 5 is marked to dscp 46. This shows normal traffic as in the row titled 0-4 in the 'incoming' column, and cos 5 traffic appears in the 40-44 row and the 'dropped' column... which can't be right.
Anyone know what the columns mean?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
jkeeffe
Level 2
Level 2
I figured this out after looking at it sideways and upside down. Here is part of the output from the command I ran on one of our 3750 switches (copy it and paste it into notepad so the rows stretch back out): 'sh mls qos int f0/35 statistics'
dscp: outgoing
0 - 4 : 63683 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 81
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 13366
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 10749 0 13653 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
On the left side X - X are the DSCP values for the five columns of that row. For example, 20 - 24 row has the number 81 in the fith column. That shows that 81 packets with the DSCP value of 24 went out of that port. In row 45 - 49, 10749 packets with DSCP of 46 and 13653 packets with DSCP value of 48 went out that port.
I finally was able to use this table to show that a video conferencing unit was truely generating voice packets with DSCP 46 (EF), video packets with DSCP 34, and call control packets with DSCP 24 (this is COS 3 that is mapped to DSCP 24 in the cos-dscp map entry.)
So to clarify, the five columns have nothing to do with Incoming, No_Change, Classified, Policed and dropped, they represent the number of packets that have the DSCP values as referred to by the far left table.
Hope this helps.
jkeeffe
Level 2
Level 2
dscp: outgoing
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
Hope this helps.
It does indeed - it's fairly obvious now you've said it!
