please help to verify my etherchannel config on 6509 switch
netman2k5
This EtherChannel config is for the same channel group 1:
interface Port-channel1
description to 6509-Core-A P1
ip address x.x.x.x y.y.y.y
ip route-cache flow
interface GigabitEthernet1/1
description to 6509-Core-A T1/1 (P1)
no ip address
ip route-cache flow
channel-group 1 mode desirable
interface GigabitEthernet2/1
description to 6509-Core-A T2/1 (P1)
no ip address
ip route-cache flow
Questions :
1/ same config on 6509 for either doing EtherChannel to switch 3548 or 2950 ?
2/ do we have the same configs on floor switches ?
Thanks in advance.
5 Replies 5
Prashanth Krishnappa
1) Yes... Just use a different channel-group number
2)You are using a L3 port channel on the 6500. Not all switches support layer 3 interfaces(example 2950/3548 does not). So with these switches you will need to configure layer 2 etherchannels.
Our 2950/3548 switches are layer 2 so please help with sample config for layer 2 etherchannels Thank you very much.
The following tech tip should help you
http://www.cisco.com/warp/public/473/144.html
Sir,
I have a last question: in "int port channel", do I need to specify ip address ? thanks.
netman2k5
here is my configs, please give some comments:
This EtherChannel config is for the same channel group 1 on 6509 switch - IOS:
ip route-cache flow
no ip address
switchport
switchport mode trunk
no ip address
switchport
config Etherchannel on 2950 switches (version 12.1)
interface FastEthernet0/2
interface FastEthernet0/3
configure Etherchannel on 3548XL switches (version 12.0) :
interface FastEthernet0/1
port group 1
port group 1
Thanks a lot.
