3725 RAS Solution + XP dial in Client Issues
gcobby
Hi All,
I have been setting up a 3725 with a Pri ISDN and a bank of MICA modems.
If I dial in with a Win 2K Pro client I connect ok, receive my IP address, Gateway, DNS etc, and I can ping around the network.
However if I dial in using Windows XP Pro, I connect, I receive an IP address but a get a default gateway of 0.0.0.0. I cannot even ping the Loopback of the router. And the router cannot ping me. If I use this same laptop I can dial my ISP and work fine!
I have checked the built in firewall in XP and this is disabled. I have also tried another XP machine, however this one does get a default gateway, but it still cannot ping or connect to any resources.
Is there something that I should be aware of to get XP working with a Cisco RAS dial up box.
I have attached the config for the 3725.
Thanks in advance
Glen
version 12.2
hostname Cisco-3725
enable secret 5
aaa new-model
aaa authentication login default group radius enable
aaa authentication login NO_AUTHEN line
aaa authentication ppp default if-needed
aaa authorization exec NO_AUTHOR none
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
aaa session-id common
ip subnet-zero
ip cef
no ip dhcp conflict logging
ip dhcp excluded-address 62.130.134.1
ip dhcp pool 0
network xx.xx.xx.0 255.255.255.224
ip address-pool dhcp-proxy-client
ip dhcp-server x.x.134.1
async-bootp dns-server 194.189.136.14 194.189.136.32
async-bootp nbns-server 194.189.132.32
isdn switch-type primary-net5
controller E1 1/0
pri-group timeslots 1-10,16
description ***** PRI ISDN Controller *****
interface Loopback0
description ***** Group Async IP Address *****
ip address x.x.x.1 255.255.255.224
interface FastEthernet0/0
ip address x.x.x.70 255.255.255.0
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
description ***** Pri Rate ISDN *****
no ip address
encapsulation ppp
isdn incoming-voice modem
no peer default ip address
no fair-queue
no cdp enable
interface Group-Async1
description ***** Digital Modem Pool *****
ip unnumbered Loopback0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer in-band
dialer idle-timeout 600
dialer-group 1
async mode interactive
peer default ip address dhcp
no keepalive
ppp authentication pap
group-range 65 94
ip classless
ip route 0.0.0.0 0.0.0.0 194.189.136.1
ip http server
dialer-list 1 protocol ip permit
no cdp run
radius-server host 194.189.132.156 auth-port 1645 acct-port 1646
radius-server timeout 10
radius-server key xxx
radius-server authorization permit missing Service-Type
line con 0
password
login authentication NO_AUTHEN
line 65 94
flush-at-activation
modem Dialin
modem autoconfigure type mica
autocommand ppp
transport preferred none
autoselect during-login
autoselect ppp
line aux 0
line vty 0 4
password
end
vkapoor5
Level 5
Level 5
See if you can find something using PPP or DHCP related debugs. You can also check for any known issues with the version that you are using.
zahmed
Could you capture "debug ppp nego" and "debug aaa authoriz" for an XP machine?
~Zulfi
slupetti
I have the same problem .Have you fix ?
The ppp debug display this :
Mar 1 00:34:14.899: As84 PPP: I pkt type 0x0021, datagramsize 97 link[ip]
Mar 1 00:34:14.899: As84 IP: Non-NCP packet, discarding
