3750 - config-register settings - help !!
nerdv
hello all,
we have 4 3750s in our isp environment. i observed two weird things. the config-register shows "0xF". i dont have a config-register command in Global config mode.
hostname#show ver
IOS (tm) C3750 Software (C3750-I5K91-M), Version 12.2(18)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 04-Feb-04 22:21 by antonino
Image text-base: 0x00003000, data-base: 0x00BDF09C
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(11r)AX, RELEASE SOFTWARE (fc1)
Configuration register is 0xF
hostname(config)#config-register ?
% Unrecognized command
Questions :
1. is the config-register for these boxes set to 0xF and shld it be like that. if yes, is there a valid explanation?
2. if i have to set it to 0x2102, how do i go about doing it
thanks everyone
sidd--
htsuji
Basically,I think that Low or Middle End Switch can't change to config-register.
For Example, 3550 series is 0x10F.etc,,,
