3850 udld error on port channel
Ashwin Jingade
I have configured 2 switches 3850 with port channel, if I enable UDLD port channel fails, it never established the connection. Even I bounce the port.
Ports will go to "erro-disable" state.
001036: *Sep  7 12:47:01.724 CET: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
001037: *Sep  7 12:47:01.732 CET: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to down
001038: *Sep  7 12:47:01.738 CET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
001039: *Sep  7 12:47:02.731 CET: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
During my investigation I found :
CSCva24225 - UDLD neighbor Failed to become bi-directional - 1
is there any solution on this ?
I am using IOS:
Switch Ports Model              SW Version        SW Image              Mode
*    1 16    WS-C3850-12XS      16.3.6            CAT3K_CAA-UNIVERSALK9 BUNDLE
23 Replies 23
@Ashwin Jingade wrote:
configured as a portchannel and Fiber cables are connected
That's not my question.  I want to know what is at the other end of the two links?
sw 1. TE1/1/1 & TE1/1/2 port channels
Last try!
One end is the 3850.  What is at the other end?
There are 2 3850 switch connected
is configured as a port channel between Te1/1/1 to Te1/1/2
SW1 I don't get any error logs
SW2 if its I enable UDLD in global mode it get err-disabled message, as per your last recommendation I disabled UDLD AGGRESSIVE in this switch still I get err-disable and port channel went down.
Hence I have disabled UDLD in global mode not without any issue its working.
Did you remove UDLD aggressive from BOTH switches or one?
You've provided the output to the command "sh interface <PORT> contr" from one switch.  Can I see the output from the other switch?
I have disabled UDLD aggressive on both switch and enabled global mode UDLD but issue remain same,
here are the out puts:
SW 1
x-xx-xx-011#sh int t1/1/1 status
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/1/1   R-UK-CH-021        notconnect   1            full   1000 1000BaseSX SFP
x-xx-xx-011#sh int t1/1/2 status
Te1/1/2   R-UK-CH-021        notconnect   1            full   1000 1000BaseSX SFP
x-xx-xx-011#sh run | i udld
udld enable
errdisable recovery cause udld
sh run int po1
Building configuration...
Current configuration : 126 bytes
interface Port-channel1
 description
 switchport trunk native vlan 195
 switchport mode trunk
x-xx-xx-011#sh int te1/1/1 controller
TenGigabitEthernet1/1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is cc98.91f1.7a0d (bia cc98.91f1.7a0d)
  Description: R-UK-CH-021
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:03:26, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     16447 packets input, 2519894 bytes, 0 no buffer
     Received 9333 broadcasts (9257 multicasts)
     0 watchdog, 9257 multicast, 0 pause input
     19631 packets output, 3274160 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Transmit                  TenGigabitEthernet1/1/1               Receive
      3274160 Total bytes                     2519894 Total bytes
            5 Unicast frames                     7114 Unicast frames
          320 Unicast bytes                    455296 Unicast bytes
        19559 Multicast frames                   9257 Multicast frames
      3269304 Multicast bytes                 2059450 Multicast bytes
           67 Broadcast frames                     76 Broadcast frames
         4536 Broadcast bytes                    5148 Broadcast bytes
            0 System FCS error frames               0 IpgViolation frames
            0 MacUnderrun frames                    0 MacOverrun frames
            0 Pause frames                          0 Pause frames
            0 Cos 0 Pause frames                    0 Cos 0 Pause frames
            0 Cos 1 Pause frames                    0 Cos 1 Pause frames
            0 Cos 2 Pause frames                    0 Cos 2 Pause frames
            0 Cos 3 Pause frames                    0 Cos 3 Pause frames
            0 Cos 4 Pause frames                    0 Cos 4 Pause frames
            0 Cos 5 Pause frames                    0 Cos 5 Pause frames
            0 Cos 6 Pause frames                    0 Cos 6 Pause frames
            0 Cos 7 Pause frames                    0 Cos 7 Pause frames
            0 Oam frames                            0 OamProcessed frames
            0 Oam frames                            0 OamDropped frames
         2406 Minimum size frames                9525 Minimum size frames
        13508 65 to 127 byte frames              3186 65 to 127 byte frames
            0 128 to 255 byte frames               20 128 to 255 byte frames
         3715 256 to 511 byte frames             3714 256 to 511 byte frames
            2 512 to 1023 byte frames               2 512 to 1023 byte frames
            0 1024 to 1518 byte frames              0 1024 to 1518 byte frames
            0 1519 to 2047 byte frames              0 1519 to 2047 byte frames
            0 2048 to 4095 byte frames              0 2048 to 4095 byte frames
            0 4096 to 8191 byte frames              0 4096 to 8191 byte frames
            0 8192 to 16383 byte frames             0 8192 to 16383 byte frames
            0 16384 to 32767 byte frame             0 16384 to 32767 byte frame
            0 > 32768 byte frames                   0 > 32768 byte frames
            0 Late collision frames                 0 SymbolErr frames
            0 Excess Defer frames                   0 Collision fragments
            0 Good (1 coll) frames                  0 ValidUnderSize frames
            0 Good (>1 coll) frames                 0 InvalidOverSize frames
            0 Deferred frames                       0 ValidOverSize frames
            0 Gold frames dropped                   0 FcsErr frames
            0 Gold frames truncated
            0 Gold frames successful
            0 1 collision frames
            0 2 collision frames
            0 3 collision frames
            0 4 collision frames
            0 5 collision frames
            0 6 collision frames
            0 7 collision frames
            0 8 collision frames
            0 9 collision frames
            0 10 collision frames
            0 11 collision frames
            0 12 collision frames
            0 13 collision frames
            0 14 collision frames
            0 15 collision frames
            0 Excess collision frames
LAST UPDATE 1496 msecs AGO
 x-xx-xx-011#sh int te1/1/2 controller
TenGigabitEthernet1/1/2 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is cc98.91f1.7a0e (bia cc98.91f1.7a0e)
  Keepalive not set
  Last input never, output 00:03:33, output hang never
     656869 packets input, 47311609 bytes, 0 no buffer
     Received 649738 broadcasts (649718 multicasts)
     0 watchdog, 649718 multicast, 0 pause input
     1181112 packets output, 85920732 bytes, 0 underruns
Transmit                  TenGigabitEthernet1/1/2               Receive
     85920732 Total bytes                    47311609 Total bytes
          135 Unicast frames                     7131 Unicast frames
        17024 Unicast bytes                    456764 Unicast bytes
      1180873 Multicast frames                 649718 Multicast frames
     85896652 Multicast bytes                46853489 Multicast bytes
          104 Broadcast frames                     20 Broadcast frames
         7056 Broadcast bytes                    1356 Broadcast bytes
         2443 Minimum size frames               45020 Minimum size frames
      1174922 65 to 127 byte frames            608102 65 to 127 byte frames
            4 128 to 255 byte frames               22 128 to 255 byte frames
         3735 256 to 511 byte frames             3722 256 to 511 byte frames
            8 512 to 1023 byte frames               3 512 to 1023 byte frames
LAST UPDATE 1972 msecs AGO
SW 2:
x-xx-xx-021#sh int te1/1/1 status
Te1/1/1   R-UK-CH-011        err-disabled 1            full   1000 1000BaseSX SFP
R-UK-CH-021#sh int te1/1/2 status
Te1/1/2   R-UK-CH-011        err-disabled 1            full   1000 1000BaseSX SFP
x-xx-xx-021#sh run | i udld
udld enable
sh run int po1
 description
sh log :
Sep 12 09:40:06.312 CET: %PM-4-ERR_RECOVER: Attempting to recover from udld err-disable state on Te1/1/1
000204: *Sep 12 09:40:11.491 CET: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to up
000205: *Sep 12 09:40:12.647 CET: %PM-4-ERR_RECOVER: Attempting to recover from udld err-disable state on Te1/1/2
000206: *Sep 12 09:40:14.895 CET: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to up
000207: *Sep 12 09:40:15.109 CET: %UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Te1/1/1, aggressive mode failure detected
000208: *Sep 12 09:40:15.110 CET: %PM-4-ERR_DISABLE: udld error detected on Te1/1/1, putting Te1/1/1 in err-disable state
000209: *Sep 12 09:40:16.110 CET: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/1, changed state to down
000210: *Sep 12 09:40:17.087 CET: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/2, changed state to up
000211: *Sep 12 09:40:17.154 CET: %LINK-3-UPDOWN: Interface TenGigabitEthernet1/1/1, changed state to down
000212: *Sep 12 09:40:20.386 CET: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet1/1/2, changed state to up
000213: *Sep 12 09:40:20.509 CET: %UDLD-4-UDLD_PORT_DISABLED: UDLD disabled interface Te1/1/2, aggressive mode failure detected
000214: *Sep 12 09:40:20.509 CET: %PM-4-ERR_DISABLE: udld error detected on Te1/1/2, putting Te1/1/2 in err-disable state
x-xx-xx-021#sh int t1/1/1 controller
TenGigabitEthernet1/1/1 is down, line protocol is down (err-disabled)
  Hardware is Ten Gigabit Ethernet, address is 7486.0bbc.380d (bia 7486.0bbc.380d)
  Description: R-UK-CH-011
  Keepalive not set
  Last input never, output 00:02:07, output hang never
     18410 packets input, 3123751 bytes, 0 no buffer
     Received 18410 broadcasts (18402 multicasts)
     0 watchdog, 18402 multicast, 0 pause input
     15426 packets output, 2400626 bytes, 0 underruns
     10 unknown protocol drops
      2400626 Total bytes                     3123751 Total bytes
         6896 Unicast frames                        0 Unicast frames
       441344 Unicast bytes                         0 Unicast bytes
         8512 Multicast frames                  18402 Multicast frames
      1958062 Multicast bytes                 3123207 Multicast bytes
           18 Broadcast frames                      8 Broadcast frames
         1220 Broadcast bytes                     544 Broadcast bytes
         9205 Minimum size frames                2313 Minimum size frames
         2617 65 to 127 byte frames             12504 65 to 127 byte frames
           10 128 to 255 byte frames                0 128 to 255 byte frames
         3594 256 to 511 byte frames             3593 256 to 511 byte frames
            0 512 to 1023 byte frames               0 512 to 1023 byte frames
LAST UPDATE 128125 msecs AGO
x-xx-xx-021#sh int t1/1/2 controller
TenGigabitEthernet1/1/2 is down, line protocol is down (err-disabled)
  Hardware is Ten Gigabit Ethernet, address is 7486.0bbc.380e (bia 7486.0bbc.380e)
  Keepalive not set
  Last input never, output 00:02:12, output hang never
     1146230 packets input, 83374465 bytes, 0 no buffer
     Received 1146103 broadcasts (1146055 multicasts)
     0 watchdog, 1146055 multicast, 0 pause input
     637505 packets output, 45908770 bytes, 0 underruns
     8 unknown protocol drops
     45908770 Total bytes                    83374465 Total bytes
         6918 Unicast frames                      127 Unicast frames
       443132 Unicast bytes                     15681 Unicast bytes
       630586 Multicast frames                1146055 Multicast frames
     45465570 Multicast bytes                83355528 Multicast bytes
            1 Broadcast frames                     48 Broadcast frames
           68 Broadcast bytes                    3256 Broadcast bytes
        43688 Minimum size frames                2360 Minimum size frames
       590201 65 to 127 byte frames           1140250 65 to 127 byte frames
           16 128 to 255 byte frames                4 128 to 255 byte frames
         3599 256 to 511 byte frames             3611 256 to 511 byte frames
            1 512 to 1023 byte frames               5 512 to 1023 byte frames
LAST UPDATE 134803 msecs AGO
udld enable
<DOUBLE FACEPALM>
I fixed the error, of UDLD.
Image was installed in Bundel mode.
I have changed to Install mode now everything is working.
Thanks for your suggestion and now I have disabled UDLD aggressive on these devices.
Since yesterday night devices are working fine. :)
Have a nice day.
Glad to hear all working and good for your inputs.
BB
