5505 sup3 NFFC won't boot, sup 2 will. Clearing DRAM...Do
jeff
My company just purchased a 5505, with a sup2 MMF(WS-X5506)and four WS-X5224. With this hardware, the system boots fine. When I installed a sup3 NFFC (WS-X5530), remaining hardware same, it won't boot.
Console shows:
System Bootstrap, Version 3.1(2)
Copyright (c) 1994-1997 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing PCI subsystem
PCMCIA_RESET: 0xbe840204
Initializing main memory
Config DRAM parity check
Initializing shared memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Presto processor with 65536 Kbytes of main memory
Autoboot executing command: "boot bootflash:
CCCCCC (removed many more C's)
Uncompressing file: ############## (again, removed extra #'s)
System Power On Diagnostics
NVRAM Size ...................512 KB
Testing ID Prom ..............Passed
DPRAM Size ...................16 KB
Testing DPRAM Data 0x55 ......Passed
Testing DPRAM Data 0xaa ......Passed
Testing DPRAM Address ........Passed
Clearing DPRAM ...............Done
System DRAM Memory Size ......64 MB
Testing DRAM Data 0x55 .......
Testing DRAM Data 0xaa .......Passed
Testing DRAM Address .........Passed
Clearing DRAM ................Do
and that's as far as it goes. I didn't drop the "ne" after Do, they don't show up, and I have to shut the power off, and turn on to regain control.
In ROMmon:
rommon 7 > dir bootflash:
File size Checksum File name
5367763 bytes (0x51e7d3) 0x40fe2012 cat5000-sup3.6-3-10.bin
rommon 8 >
rommon 2 > meminfo
Main memory size: 64 MB.
Packet memory size: 0 MB
Main memory size: 0x4000000
Available main memory starts at 0xa000e000, size 0x3ff2000
NVRAM size: 0x20000
Parity Map for the DRAM Banks
Socket 0 in Bank 0 Has No Parity
Socket 1 in Bank 0 Has No Parity
Socket 0 in Bank 1 Has No Parity
Socket 1 in Bank 1 Has No Parity
rommon 3 >
rommon 3 > sysret
System Return Info:
count: 19, reason: reset
pc:0x0, error address: 0x0
Stack Trace:
FP: 0x00000000, PC: 0x00000000
rommon 4 >
rommon 12 > stack
stack: kernel context state is invalid, can not proceed
rommon 13 >
rommon 19 > set
PS1=rommon ! >
BOOT=bootflash:,1;
CONFIG_FILE=slot0:switch.cfg
?=0
rommon 20 > CONFIG_FILE=bootflash:
rommon 21 > set
PS1=rommon ! >
BOOT=bootflash:,1;
?=0
We have a bunch of 2900's, but this is the first 5505 the company has thrown at me. While I can usually solve 2900 problems, I am inexperienced on the 5500 and blades.
I would appreciate any and all help.
Thanks a million for any help, and your time,
Jeff
CCCCCC
jt.silas
Hey Jeff...You may be running an old version of catos..you need to verify that your current version of catos / boot version....will support that sup3 module, if not then you need to upgrade to at least 6.4(17)....as long as you have at least 64megs of dram.
