6504's with 3 vlans and MHSRP
gb1241
I have two 6504 switches, MSFC's in both. serving what I'd like to have as a 3 subnetted vlan network which consist of 1 subnetted class C.
All of my servers have two nics and are connected to each of the two 6504's.
a. Primary - Production classC/26
b. Secondary - Failover & Backup classC/26
c. DMZ classC/26
I'd like to make the A 6504 the primary for prodcutin and dmz traffic and the B 6504 the primary path for Backup traffic. I'd also like the B 6504 to serve as a fialover in the event that first switch or it's connection the to core fails.
1. Is there a way to do this with MHSRP?
2. What should my Vlan configuration be? Master - Master ?
Ganesh Hariharan
You can use multiple HSRP configuration for load balancing and making active/active configuration with failover for each other in your architucture,check out the below link for brief explanation with configuration of MHSRP in network.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
