The reduced memory may be due to the catos upgrade, when you get new releases of software it is usual for them to use more memory, both in Flash and DRAM.
Also, each module inserted in to the chassis will have a memory requirement, so adding additional modules will reduce the amount of additional system memory, which is why your other system with no ids is fine.
Either downgrade your catos or install extra DRAM.
HTH.
