6509 Module removal causes supervisor freeze
m-rosebury
Any ideas why a 6509 Native IOS 12.1(20)E2 WS-X6416-GBIC module powered down causes the supervisor and system to freeze when removed. Does Native IOS not support OIR?
These are the syslog message generated.
%C6KERRDETECT-SP-4-SWBUSSTALL: The switching bus is experiencing stall for 3 seconds'.
%EARL-SP-2-SWITCH_BUS_TIMEOUT: Switching bus timeout detected. System not switch packets for 1 sec
%C6KERRDETECT-SP-4-SWBUSSTALL_RECOVERED: The switching bus stall is recovered and data traffic switching continues
On reinsertion the system immediately springs to life again.
pmajumder
Level 3
Level 3
It does support OIR. Is this a fabric-enabled module?
If so OIR will cause traffic flow interruption. Also before removal try shutting down the module to see if it helps:
hw-module module # shutdown
