01-05-2005 02:14 PM - edited 03-02-2019 08:54 PM
Can anyone shed a light on this problem? Everything seems fine but getting the following error...
thanks
Serhat
Minor hardware problem in Module # 15
Use 'show test 15' to see results of tests.
2005 Jan 05 15:02:41 %SYS-1-MOD_MINORFAIL:Minor problem in module 15
2005 Jan 05 15:02:41 %SYS-4-NVLOG:SYNDIAGS:Minor hardware problem in Module #15. Use 'show test 15' to see results of tests.
2005 Jan 05 15:02:42 %SYS-5-MOD_OK:Module 15(WS-F6K-MSFC2,SAL08342RQ8) is online
Console> (enable) sh test 15
Diagnostic mode: minimal (mode at next reset: minimal)
Module 15 : 1-port Multilayer Switch Feature Card
Line Card Firmware Status for Module 15 : PASS
Port Status :
Ports 1
Line Card Diag Status for Module 15 (. = Pass, F = Fail, N = N/A)
Loopback Status [Reported by Module 2] :
Ports 1
F
01-05-2005 03:26 PM
You should set it up for complete diagnostics and when you get a chance reboot the switch and see what it says . Currently it is set as minmal diags and doesn't test much when booting up .
01-05-2005 04:50 PM
I have rebooted the switch few times and did not see any problem even a minor one..
thanks
Serhat
