6509 SCP Communication Error on FLEX WAN Module
ckytony
>i have two 6509. These two 6509 have to connect to remote sites via leased
>line.
>So i have two FLEX module at each 6509, with a WAN module located at each FLEX module.
>However, after booting up, the FLEX LED module at one 6509 remains red
>(while the LED at the other 6509 is green in colour).
>Except this, the 6509 seems OK.
>The following shows the log upon booting up
>2002 Jul 20 02:08:07 %PAGP-5-PORTTOSTP:Port 3/3 joined bridge port 3/3
>2002 Jul 20 02:08:07 %PAGP-5-PORTTOSTP:Port 3/4 joined bridge port 3/4
>2002 Jul 20 02:08:08 %PAGP-5-PORTTOSTP:Port 3/6 joined bridge port 3/6
>SCP Communication error with Module 4
>2002 Jul 20 02:08:10 %SYS-5-MOD_OK:Module 4 is online
>2002 Jul 20 02:08:16 %SYS-5-MOD_OK:Module 15 is online
>Any idea what SCP communication error is..
rfroom
Serial communications protocol defines the protocol used to exchange messages between the Supervisor CPU and the line card in question.
Besides the RED status light, everything is ok? There was some cosmetic bugs issues related to this error message. What versions of software are you running on the Supevisor and MSFC.
I would suggest looking a the following for any issues. You may want to open a TAC case:
show test 4
show diag
show tech
console to the flaxwan module from the designated router "ipc-console 0", and get "sh tech" and "sh log" from the flaxwan card
