11-03-2011 08:56 AM - edited 03-03-2019 06:25 AM
Hello I need some help I have three routers 811 (independent), and the interface cellular 0 resets in all three, someone knows something about this
Oct 30 12:15:10.501: %CISCO800-2-MODEM_REMOVAL_DETECTED: Cellular0 modem is now REMOVED
Oct 30 12:15:10.501: %CISCO800-2-CELLULAR_INTERFACE_NOT_SHUTDOWN: WARNING: Cellular0 interface should be shutdown before removing modem. Reload Required to reset interface
Oct 30 12:15:17.501: %CISCO800-2-MODEM_INSERTED_DETECTED: Cellular0 modem is now INSERTED
Oct 30 12:15:25.873: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Oct 30 12:15:43.313: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
Oct 30 12:15:56.261: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
Oct 31 18:18:16.306: %CISCO800-2-MODEM_REMOVAL_DETECTED: Cellular0 modem is now REMOVED
Oct 31 18:18:16.306: %CISCO800-2-CELLULAR_INTERFACE_NOT_SHUTDOWN: WARNING: Cellular0 interface should be shutdown before removing modem. Reload Required to reset interface
Oct 31 18:18:23.402: %CISCO800-2-MODEM_INSERTED_DETECTED: Cellular0 modem is now INSERTED
Oct 31 18:18:32.134: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Oct 31 18:18:49.574: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
Oct 31 18:19:02.518: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
Oct 31 18:19:11.918: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Oct 31 18:19:24.062: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
Nov 2 23:13:52.993: %CISCO800-2-MODEM_REMOVAL_DETECTED: Cellular0 modem is now REMOVED
Nov 2 23:13:52.993: %CISCO800-2-CELLULAR_INTERFACE_NOT_SHUTDOWN: WARNING: Cellular0 interface should be shutdown before removing modem. Reload Required to reset interface
Nov 2 23:13:59.577: %CISCO800-2-MODEM_INSERTED_DETECTED: Cellular0 modem is now INSERTED
Nov 2 23:14:08.801: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
Nov 2 23:14:26.205: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
Nov 2 23:14:39.229: %CISCO800-2-MODEM_UP: Cellular0 modem is now UP.
interface Cellular0
no ip address
ip mtu 1400
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 1
dialer-group 1
async mode interactive
thank you very much
03-26-2012 10:55 AM
Hello Jonathan,
Did you get any answer ?
Unfortunatly, I don't have one for you, but I have the same problem.
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer idle-timeout 30
dialer string gsm
dialer-group 1
Andre
04-26-2012 02:27 AM
make
sh cell 0 all
and put here
09-18-2012 11:21 AM
There you go :
Hardware Information
Modem Firmware Version = K2_0_7_35AP C:/WS/F
Modem Firmware built = 03/04/10
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 302220000399572
International Mobile Equipment Identity (IMEI) = 353223046400793
Integrated Circuit Card ID (ICCID) = 8912230000006695480
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) = 14189657295
Factory Serial Number (FSN) = C9E364100171007
Modem Status = Online
Current Modem Temperature = 32 deg C, State = Normal
PRI SKU ID = 9993559, SKU Rev. = 1.2
Profile Information
Profile password Encryption level: 7
Profile 1 = ACTIVE*
PDP Type = IPv4
PDP address = 999.999.999.999
Access Point Name (APN) = staticipeast.telus.com
Authentication = CHAP
Username: user1, Password: 030752180500
* - Default profile
Data Connection Information
Data Transmitted = 10798496 bytes, Received = 10733505 bytes
Profile 1, Packet Session Status = ACTIVE
IP address = 999.999.999.999
Negotiated QOS Parameters:
Precedence = Low Priority, Delay = Class 3
Reliability = Unack GTP, LLC, Ack RLC, Protected data
Peak = 256 kB/sec, Mean = 50000 kB/hr
Traffic Class = Interactive
Uplink Max = Unknown, Guaranteed = Subscribed
Downlink Max = Unknown, Guaranteed = Subscribed
Max SDU size = 1500 bytes
SDU error ratio = 1E-4, BER = 1E-5
Profile 2, Packet Session Status = INACTIVE
Inactivity Reason = Normal inactivate state
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = HSPA (Attached)
Packet Session Status = Active
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = CAN, Network = TELUS
Mobile Country Code (MCC) = 302
Mobile Network Code (MNC) = 220
Location Area Code (LAC) = 11654
Routing Area Code (RAC) = 154
Cell ID = 14371
Primary Scrambling Code = 204
PLMN Selection = Automatic
Registered PLMN = TELUS , Abbreviated =
Service Provider =
Radio Information
Radio power mode = ON
Current Band = WCDMA 850, Channel Number = 1087
Current RSSI = -85 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0xCC
RSCP = -86 dBm, ECIO = -4 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Profile Information
Profile 1 = ACTIVE*
PDP Type = IPv4
* - Default profile
Network Information
Cell ID = 14371
Service Provider =
Radio Information
Cell 1
SIM Status = OK
