891f-k9 upgrade issues
JMaartenW
I have issues upgrading this router due to "not enough space" problems
I was unable to upgrade the running-config tftp
(copy tftp://ip address/c800-universalk9-mz.SPA.157-3.M1.bin run)
so I uploaded the config to Flash (copy tftp://ip address/c800-universalk9-mz.SPA.157-3.M1.bin flash)
I then deleted the old config and attempted to ensure the router would boot from the new config only.
even though the new config now shows correctly in Flash and in Rommon the router still will only boot into Rommon what am I missing here? do I really have to upgrade the memory?
rommon 7 > dir flash:
Directory of flash:
2      96136084  -rw-     c800-universalk9-mz.SPA.157-3.M1.bin
16720    780       -rw-     vlan.dat
40190    0         drw-     managed
40194    0         drw-     eem
SIDCIS91FVOIP1#sh flash:
-#- --length-- -----date/time------ path
1     96136084 Sep 18 2018 04:42:46 +01:00 c800-universalk9-mz.SPA.157-3.M1.bin
2          780 Dec 15 2017 15:00:58 +00:00 vlan.dat
3            0 Sep 17 2018 19:24:28 +01:00 managed
4            0 Sep 17 2018 19:24:30 +01:00 managed/odm
5        21341 Sep 17 2018 19:24:34 +01:00 managed/odm/cg-dm.odm
6        21341 Sep 17 2018 19:24:36 +01:00 managed/odm/cg-nms.odm
7        21341 Sep 17 2018 19:24:38 +01:00 managed/odm/cg-dm-1.0.odm
8        21341 Sep 17 2018 19:24:38 +01:00 managed/odm/cg-nms-1.0.odm
9            0 Sep 17 2018 19:24:32 +01:00 managed/scripts
10        3235 Sep 17 2018 19:24:36 +01:00 managed/scripts/cg-nms-scripts.tcl
11        3235 Sep 17 2018 19:24:40 +01:00 managed/scripts/cg-nms-scripts-1.0.tcl
12           0 Sep 17 2018 19:24:32 +01:00 managed/reprovision
13           0 Sep 17 2018 19:24:34 +01:00 eem
160235520 bytes available (96268288 bytes used)
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.157-3.M1.bin
boot-end-marker
You need to change the config register:
config-register 0x2102
...should do the trick.
cheers,
Seb.
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/50421-config-register-use.html
Seb Rupik
I'm a little confused. The output from the second command indicates that you have successfuly booted and are in EXEC.
When you have the SIDCIS91FVOIP1# prompt, what is the output of sh ver?
cheers,
Seb.
I am able to boot into the IOS but only manually from ROMMON the device will not power up into ios automatically. is it something to do with this bootstrap which is still showing the old version how do I change that?
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.7(3)M1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 30-Nov-17 03:00 by prod_rel_team
ROM: System Bootstrap, Version 15.4(1r)T1, RELEASE SOFTWARE (fc1)
SIDCIS91FVOIP1 uptime is 1 hour, 55 minutes
System returned to ROM by reload at 13:30:26 PCTime Tue Sep 18 2018
System image file is "flash:c800-universalk9-mz.SPA.157-3.M1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco C891F-K9 (revision 1.0) with 488524K/35763K bytes of memory.
Processor board ID FCZ*********3
1 FastEthernet interface
9 Gigabit Ethernet interfaces
1 Serial interface
1 ISDN Basic Rate interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*1        C891F-K9              FCZ*******3
License Information for 'c800'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
Configuration register is 0x2100
cheers,
Seb.
do you know what!!! I've looked and changed that several times and now realise the typo in 0x2100
THANK YOU so much!! i'm off to specsavers :)
