About Cisco3750 connect ExtremeSwitch Problem ?
ted_wen
Hello All :
I had meet the problem about cisoc3750 connect to
Extreme Switch .
At Begining the link is work fine ! but after 5 min / 10 min , the link dow/up flapping . Then come back again ! even config " No keepalive , speed 100 ,
duplex full " Still the same problem ??
I had replace the Cisco3750 to Cisco2950 , the problem still the same .....
So does anyone could help me what's the problem is ?
2 Accepted Solutions
Which interface connects to the Extreme switch? Can you try hard coding Speed/duplex on both sides? Also configure the following under the interfaces since you are not trunking
3750-B(config-if)#switchport mode access
3750-B(config-if)#switchport nonegotiate
Hi!
It works!
Thank you very much!
Best Regards,
Jemin Huang
6 Replies 6
Prashanth Krishnappa
Can you provide more details such as what IOS you are running on the 3750, the config and sh interface for the interface in question.
What model of extreme switch is it and what is the interface on it configured as?
The following IOS versions were tested.
And we got the same results.
c3750-i5-tar.121-19.EA1d.tar
c3750-i5-tar.122-20.SE1.tar
c3750-i5-tar.122-20.SE3.tar
c3750-i9-tar.121-19.EA1d.tar
Jemin Huang
The attached file is the config file of the 3750.
The tested modules of Extreme switches include
Extreme Alpine 3804 6.2.1 (Build 27),
Summit 200-24 6.2e.2 (Build 16), and
Summit 24-E2 e2.2.00 (Build 18).
Jemin Huang
Uplink interface is Fastethernet 1/0/48
Hi!
It works!
Best Regards,
Jemin Huang
