ASR1000-SIP10 doesn't get recognized on ASR1000-RP2 with ( 16.9.4 IOS XE )
proziumwtf
I've upgraded 2 of our ASR1000-RP2 ( they are in ASR1004s ) to 16.9.4 IOS XE. The previous version was : 3.13 ( 154-3 ) . Since the upgrade the ASR1000-SIP10 doesn't get recognized . It detects that something is in slot 0
*Oct 28 16:34:33.512: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
because of the above message . But it seems that it's stuck on booting. Everything works fine when I boot up the lower version.
Router#show platform
Chassis type: ASR1004
Slot Type State Insert time (ago)
0 booting 00:18:41
1 ASR1000-SIP40 ok 00:18:41
1/0 SPA-1X10GE-L-V2 ok 00:16:42
1/1 SPA-1X10GE-L-V2 ok 00:16:29
1/2 SPA-1X10GE-L-V2 ok 00:16:17
1/3 SPA-1X10GE-L-V2 ok 00:16:10
R0 ASR1000-RP2 ok, active 00:18:41
F0 ASR1000-ESP20 ok, active 00:18:41
P0 TBD000000000000000 ok 00:17:43
P1 ASR1004-PWR-AC ok 00:17:41
Slot CPLD Version Firmware Version
0 N/A N/A
1 00200800 15.5(3r)S1
R0 10021901 15.3(3r)S
F0 08041102 15.3(3r)S
I have tried the following :
upgrade hw-programmable cpld filename bootflash:asr1000-hw-programmables.16.08.01.SPA.pkg 0
and the output is :
/usr/binos/conf/mcp_upgrade_hwprg_utils.sh: line 31: ctrlr_type: unbound variable
/usr/binos/conf/mcp_upgrade_hwprg_cmds.sh: line 243: $4: unbound variable
This is what I get when I boot up the 154-3 IOS :
Router#sh platform
0 ASR1000-SIP10 ok 00:03:05
1 ASR1000-SIP40 ok 00:03:05
1/0 SPA-1X10GE-L-V2 ok 00:01:57
1/1 SPA-1X10GE-L-V2 ok 00:01:54
1/2 SPA-1X10GE-L-V2 ok 00:01:47
1/3 SPA-1X10GE-L-V2 ok 00:01:40
R0 ASR1000-RP2 ok, active 00:03:05
F0 ASR1000-ESP20 ok, active 00:03:05
P0 TBD000000000000000 ok 00:02:45
P1 ASR1004-PWR-AC ok 00:02:44
0 09111601 16.3(2r)
Any ideas on how to make the ASR1000-SIP10s work?
Leo Laohoo
The output shows the ROMMON/Bootstrap wasn't upgraded.
Did someone read the Release Notes carefully?
proziumwtf
Solved : The SIP10 Cards is not supported on the 16.9.4 . We will have to upgrade to SIP40.
