ATM Queueing and CRC Error Help
sross35
I am trying to work on the input errors and CRCs on the second interface below. The only difference I can see is the queueing strategy and the autovc creation on the second interface. The IOS for the top router is 12.2(8)T5 and the second one is 12.3(1).
ATM1/0 is up, line protocol is up
Hardware is ENHANCED ATM PA
MTU 4470 bytes, sub MTU 4470, BW 40704 Kbit, DLY 190 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5
4095 maximum active VCs, 85 current VCCs
VC idle disconnect time: 300 seconds
2 carrier transitions
Last input 00:00:04, output 00:00:00, output hang never
Last clearing of "show interface" counters 7w1d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 71755
Queueing strategy: None
5 minute input rate 159000 bits/sec, 43 packets/sec
5 minute output rate 239000 bits/sec, 113 packets/sec
181861255 packets input, 2514855497 bytes, 133231 no buffer
Received 1001129 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
639284334 packets output, 2243953228 bytes, 0 underruns
The one giving trouble is this one:
reliability 255/255, txload 5/255, rxload 1/255
4095 maximum active VCs, 93 current VCCs
VC Auto Creation Disabled.
2066 carrier transitions
Last input 00:00:10, output 00:00:00, output hang never
Last clearing of "show interface" counters 08:44:16
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 929
Queueing strategy: Per VC Queueing
5 minute input rate 144000 bits/sec, 115 packets/sec
5 minute output rate 835000 bits/sec, 321 packets/sec
1786981 packets input, 400051114 bytes, 638 no buffer
Received 5809 broadcasts, 0 runts, 0 giants, 0 throttles
9714 input errors, 9714 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
7904022 packets output, 1634661120 bytes, 0 underruns
The router that has no errors has per vc queue drops and the router that has errors under the atm interface has no per vc queue drops as shown below.
router with no CRC errors
Interface ATM1/0 VC 0/500
Queueing strategy: fifo
Output queue 0/40, 819 drops per VC
Interface ATM1/0 VC 0/32
Output queue 0/40, 863 drops per VC
Interface ATM1/0 VC 0/33
Output queue 0/40, 805 drops per VC
router with CRC errors
Interface ATM1/0 VC 0/31
Output queue 0/40, 0 drops per VC
Any help would be greatly appreciated.
6 Replies 6
deilert
Level 6
Level 6
can you paste in a 'sh atm pvc 0/31' 0/32, 0/33
I beleive you are overutinging your pvcs and you are getting AAl 5 errors that are being registered as CRC's
sh atm pvc 0/31
ATM1/0.1: VCD: 1, VPI: 0, VCI: 31
UBR, PeakRate: 40704 (96000 cps)
AAL5-LLC/SNAP, etype:0x0, Flags: 0xC20, VCmode: 0x0
OAM frequency: 0 second(s), OAM retry frequency: 1 second(s)
OAM up retry count: 3, OAM down retry count: 5
OAM Loopback status: OAM Disabled
OAM Managed VC Status: Not Managed
ILMI Managed VC status: Not Managed
VC TxRingLimit: 40 particles
VC Rx Limit: 480 particles
InARP frequency: 15 minutes(s)
Transmit priority 6
InPkts: 5683, OutPkts: 23400, InBytes: 668093, OutBytes: 2282815
InCells: 16693, OutCells: 57028
InPRoc: 147, OutPRoc: 20053
InFast: 5536, OutFast: 3347, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
InCellDrops: 0, OutCellDrops: 0
InByteDrops: 0, OutByteDrops: 0
CrcErrors: 15, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0, Cells: 0
OAM cells received: 0
F5 InEndloop: 0, F5 InSegloop: 0, F5 InAIS: 0, F5 InRDI: 0
F4 InEndloop: 0, F4 InSegloop: 0, F4 InAIS: 0, F4 InRDI: 0
OAM cells sent: 0
F5 OutEndloop: 0, F5 OutSegloop: 0, F5 OutRDI: 0
F4 OutEndloop: 0, F4 OutSegloop: 0, F4 OutRDI: 0
OAM cell drops: 0
Status: UP
sh atm pvc 0/32
ATM1/0.2: VCD: 2, VPI: 0, VCI: 32
Transmit priority 6
InPkts: 0, OutPkts: 22482, InBytes: 0, OutBytes: 2224152
InCells: 0, OutCells: 55205
InPRoc: 0, OutPRoc: 19982
InFast: 0, OutFast: 2500, InAS: 0, OutAS: 0
CrcErrors: 34, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
OAM cells sent: 0
OAM cell drops: 0
Status: UP
#sh atm pvc 0/33
ATM1/0.3: VCD: 3, VPI: 0, VCI: 33
Transmit priority 6
InPkts: 476, OutPkts: 21862, InBytes: 62473, OutBytes: 2308588
InCells: 1553, OutCells: 56762
InPRoc: 15, OutPRoc: 19099
InFast: 461, OutFast: 2763, InAS: 0, OutAS: 0
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
OAM cells sent: 0
OAM cell drops: 0
Status: UP
the CRC error counter shown in this command is AAL 5 errors , what happens is you exceed your contracted rate and some cells are dropped. When the SAR is reassembling the cells in to ip packets there is some cells missing and the IP packet fails the CRC check. hence the crc counter increments ,
The only thing is that the crc's that are listed under your PVC does not match what your interface shows . Did you clear the counters prior to collecting these stats ?
You may want to look at the pvc's on the remote side also.
most of the time you can fix this issue by applying PCR & SCR values on the ATM PVC
pvc 0/31
ubr 6000 (if 6Mb is your contracted rate )
I CRC error's do not match because there are over 100 pvc's and I just gave you three. I have cleared the counters on the ATM interface and the CRC's increment about 20 a minute. This is for a DSLAM.
Why wouldn't I get CRCs on the top interface without having the ubr 6000 statement? I will go ahead and read up on this and give it a try. Any other suggestions?
I was just using 6000 as an example , you should traffic shape each side to match your contracted rate . This way you do not exceed your contracted rate , If you do not exceed your contracted rate then you will not get your cells tagged . refer to this URL
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_implementation_design_guide_chapter09186a008019994d.html
I will give it a try. Thanks for the information.
I am still confused why I am not having issues on the other router pvc's and the configuration is the same whether it is correct or not.
