Basic troubleshooting tips. FT1 connection 1720.
kbozung
I'm troubleshooting intallation of a fractional T1 circuit. I'm working with the worst ISP on earth they have pretty much told me I'm on my own. They are refusing to help so I'm trying to do some troubleshooting to either figure out the problem or have some evidence to put it back on them. I know this is a very simple config but please look for any errors. I'm getting "Serial0 is up, line protocol is down"
I'm not very familiar with loopback testing, any tips?
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname TBCS-1720
enable password ********
memory-size iomem 25
ip subnet-zero
ip audit notify log
ip audit po max-events 100
interface FastEthernet0
ip address 192.168.0.5 255.255.255.0
speed auto
full-duplex
interface Serial0
description Fractional T1
ip address 65.***.***.185 255.255.255.248
encapsulation ppp
service-module t1 timeslots 1-6
service-module t1 remote-alarm-enable
router rip
version 2
network 65.0.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0 permanent
no ip http server
snmp-server community public RO
snmp-server location Traverse Bay Community
snmp-server contact Kevin Bozung, Safety Net
snmp-server enable traps tty
line con 0
line aux 0
line vty 0
password ********
login
line vty 1 4
login
smalkeric
Level 6
Level 6
The following are some steps you can take to isolate the problem:
Perform DSU/CSU loopback tests. During local loopback, enter the show interface ser0 command. If the line protocol is shown as up, there might be a problem with the telephone company, or the remote router might be down.
Refer to the Hardware Installation Guide to confirm that your router is correctly installed, using the appropriate cables.
Connect the leased line to another port, if possible. If the connection comes up, there is a hardware failure on the Serial 0 port. Contact your Cisco reseller.
Please refer the following for more troubleshooting steps for leased line.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_configuration_guide_chapter09186a008007cd3d.html
