11-04-2003 12:02 PM - edited 03-02-2019 11:28 AM
I recently installed LMS 2.2. I am looking for the best method of inventorying all devices. I have manual added each device up to this point which is only a handful. I thought about using the ANI server to sync up with the essentials database, but keep getting errors.I have yet to get this to work. Any advice on getting that to work or is it better to manually enter each device. Eventually there will be close to 500 devices to manage. Thanks
11-04-2003 01:00 PM
You can create a csv file and then import all devices in RME at once.
11-05-2003 05:24 AM
Yes, but there are 37 sites and each site will be installed at different times.
11-05-2003 06:27 AM
Hello. The easiest way would probably be to sync with Campus if possible. I would be inclined to focus on sorting this issue out. Are you getting errors when you try to sync or when you try to discover the network ?
If you get an error sync'ing then what is that error message ?
If you experience errors during discovery then try running through the troubleshooting tips on the following link: "Troubleshooting the ANI Discovery Used by Campus Manager and User Tracking" - http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml
11-05-2003 08:30 AM
No problem in the discovery part. T
he error message in the Sync Log is
ERROR:Send setCredentials to Essentials Exceptions=java.lang NumberFormatException
Now I have another problem. I tried to enter some switches manually they failed and I cannot get the deleted from the suspended state.The message they gave me when they failed was Cannot commit to groups or annotations.
