BFD static problem
Lei.LIM
I set up BFD and shut down R2 gigabitethernet 0/1.
And the routing table of R1.
There is still routing to 3.3.3.3.
Did I set it up wrong?
In this situation, is it impossible to remove the routing of 3.3.3.3 from the routing table of R1?
Thank you.
15 Replies 15
can I see the config of BFD ?
here
thanks
BFD detect the 192.168.1.2 next-hop UP not the 192168.2.x?
this is why the BFD not detect this down interface
to make you Lab work
1- add SW between two router R1 and R2
2- shut the link between SW and R1
Well, thank you for your answer.
If so, what protocol should be used in this situation to remove routing from the routing table of R1 to 3.3.3.3?
Also, could you answer my other questions about the outgoing interface?
Thank you.
for outing interface, I will do lab and test my idea first.
for this case
IP SLA reachability
is good solution here
OK I'll waiting for your answer
And I'll looking for IP SLA reachability's detail
thank you for your help!
Is it possible if R2 gigabitethernet 0/1 is down,
Can R1 detect link down, and remove 3.3.3.3 routing table?
If it possible can you tell me R1's basic config?
thanks
ip sla 10
icmp-echo 192.168.2.2
ip sla schedule 10 life forever start now
track 10 ip sla 10 reachability
ip route 3.3.3.3 255.255.255.255 192.168.1.2 track 10
Do I need to add 192.168.2.0 255.255.255.0 192.168.1.2 routing on R1?
Is there any way possible without this routing?
thanks
since it not direct connect then you need this static route.
So I need to check if loopback ip is output through the outgoing interface. Ha ha.
If this is possible, I think it is probably possible to construct it.
What do you think?
check my answer above
the R1-R2 interface not be down (as photo attach)
the R2-R3 down
How R1 detect it??
you need IP SLA
otherwise the R1 always forward traffic and traffic DROP in R2.
second for R1-R2
that why I ask you add SW, try add SW, and shut down the interface in R2, Does R1 detect it?
NO
here you need IP SLA.
I'll check more
thank you!
