02-03-2005 03:41 AM - edited 03-02-2019 09:27 PM
Hi All,
I have tow routers frame-relay back to back and configuring bgp. The problem is that no bgp connection/routing update between the two routers.
here is the config
nterface Loopback1
ip address 10.0.199.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.199.242 255.255.255.240
speed 100
full-duplex
interface Serial0/3/0
bandwidth 2048
no ip address
encapsulation frame-relay IETF
no keepalive
frame-relay lmi-type ansi
interface Serial0/3/0.1 point-to-point
ip unnumbered Loopback1
frame-relay interface-dlci 101 IETF
router bgp 100
no synchronization
bgp log-neighbor-changes
network 10.0.199.1 mask 255.255.255.255
network 10.1.0.0 mask 255.255.0.0
timers bgp 10 30
neighbor 10.0.199.2 remote-as 200
neighbor 10.0.199.2 update-source Loopback1
no auto-summary
................bgp upadte...................
w2-5-r01#sh ip bgp neighbors
BGP neighbor is 10.0.199.2, remote AS 100, external link
BGP version 4, remote router ID 0.0.0.0
BGP state = Active
Last read 00:53:24, hold time is 30, keepalive interval is 10 seconds
Configured hold time is 30,keepalive interval is 10 seconds, Minimum holdtime
from neighbor is 0 seconds
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 0 0
Notifications: 0 0
Updates: 0 0
Keepalives: 0 0
Route Refresh: 0 0
Total: 0 0
Default minimum time between advertisement runs is 30 seconds
For address family: BGP IPv4
BGP table version 2, neighbor version 0/0
Output queue size : 0
Index 1, Offset 0, Mask 0x2
1 update-group member
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 0 0
Prefixes Total: 0 0
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Used as multipath: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 0, min 0
Connections established 0; dropped 0
Last reset never
External BGP neighbor may be up to 2 hops away.
No active TCP connection
.................neigh router.............................
interface Loopback1
ip address 10.0.199.2 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
ip address 10.2.199.242 255.255.255.240
speed 100
full-duplex
bandwidth 2048
no ip address
no keepalive
frame-relay interface-dlci 102 IETF
router bgp 200
no synchronization
network 10.0.199.1 mask 55.255.255.255
network 10.2.0.0 mask 255.255.0.0
timers bgp 10 30
neighbor 10.0.199.1 remote-as 100
neighbor 10.0.199.1 update-source Loopback1
no auto-summary
I was told to add nei x.x.x.x ebgp muilthop 3 for both routers, i have added this but still the bgp on both router don't see local network but see loopback ip addess and no bgp connection between the routers
02-03-2005 05:10 AM
Have you been able to ping from one loopback to the other? Because you are using "ip unnumbered" on the freme-relay point-to-point, you should probably have a static route on each router pointing at the other as follow:
rtr1:
ip route 10.0.199.2 255.255.255.255 Serial0/3/0.1
rtr2:
ip route 10.0.199.1 255.255.255.255 Serial0/3/0.1
You could also remove the ip unnumbered on the frame-relay link and replace it by an ip address.
Hope this helps,
02-03-2005 06:39 AM
I added static routes and changed dlci so that both end have same number. Now router can est bgp connection but both bgp routers can't see/advt their local network 10.1.199.0/28 and 10.2.199.0/28 respectively.
bgp-routes
gw2-5-r01#sh ip rou
10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C 10.2.199.240/28 is directly connected, FastEthernet0/1
S 10.0.199.1/32 is directly connected, Serial0/3/0.1
C 10.0.199.2/32 is directly connected, Loopback1
gw2-5-r01#sh ip bg
gw2-5-r01#sh ip bgp
BGP table version is 7, local router ID is 10.0.199.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
r> 10.0.199.1/32 10.0.199.1 0 0 100 i
*> 10.0.199.2/32 0.0.0.0 0 32768 i
gw2-5-r01#
w1-5-r01#sh ip rou
Gateway of last resort is not set
C 10.1.199.240/28 is directly connected, FastEthernet0/1
C 10.0.199.1/32 is directly connected, Loopback1
S 10.0.199.2/32 is directly connected, Serial0/3/0.1
gw1-5-r01#sh ip bgp
BGP table version is 4, local router ID is 10.0.199.1
*> 10.0.199.1/32 0.0.0.0 0 32768 i
r> 10.0.199.2/32 10.0.199.2 0 0 200 i
gw1-5-r01#
regards
02-03-2005 06:53 AM
Have you tried network 10.1.199.0 mask 255.255.255.240 ? I think both the subnet base and the mask must match exactly the network you want to advertise.
Kevin Dorrell
Luxembourg
02-03-2005 08:42 AM
Unlike interior gateway protocols like EIGRP and OSPF, where any prefix contained in the "network" statement will be advertised, in BGP, the line "network 10.2.0.0 mask 255.255.0.0" will only advertise the prefix 10.2/16 and NO others. To advertise 10.2.199.240/28 you need to use the line "network 10.2.199.240 mask 255.255.255.240" instead.
Don't feel too embarrassed, it is probable that every BGP newbie has been bitten by this behavior. Been there, done that, been burnt :-)
Note also that in your case, you could also avoid the problem by adding the line "redistribute connected" to your BGP configuration.
Good luck and have fun!
Vincent C Jones
02-04-2005 01:36 AM
Thanks for your explanation, Im not embarrassed at all I guess this is how we all learn (learn from our mistakes) and hopefully I wont be bitten twice!!!.
02-03-2005 05:54 AM
Execute the command "show ip route 10.0.199.2" on your first router. The answer should tell you what your problem is. You need to fix it with an explicit route (either learned via an interior gateway protocol or defined by a static route). One other gotcha is that the route must be explicit. BGP will not use the default route for neighbor set up.
Vincent C Jones
02-03-2005 08:10 AM
Thanks, i have added static routes for both network and bgp is working fine now.
it's looks like any network that falls outside mayor subnets /8/16/24 will need to have explicit static route.......is reason for this ???.
02-03-2005 08:33 AM
The IOS tries to match the network statement with a RIB entry in order to originate the prefix. It has to be a perfect match for it to work. The rule for the network is as follow:
If you specify a mask, IOS taks this mask in consideration. If you don't the classfull mask is used (ie class A = 8bits, B = 16 and C = 24).
Hope this helps,
