BGP problem
Ahmede
BGP was up and suddenley it went down and it doesn't want to come up again.. We removed all the BGP config and it just came down to the neighbor statments but still down.. We ran debug for TCP and BGP and here's the output..
112828: May 9 18:00:20.160: TCP0: Data repacketized, seq 2642756153, sent 56 byte
112829: May 9 18:00:26.024: TCB63A095A0 created
112830: May 9 18:00:26.024: TCP0: state was LISTEN -> SYNRCVD [179 -> 10.133.23
.17(15269)]
112831: May 9 18:00:26.024: TCP0: Connection to 10.133.23.17:15269, received MSS 1460, MSS is 516
112832: May 9 18:00:26.024: TCP: sending SYN, seq 2151872273, ack 2653104385
112833: May 9 18:00:26.024: TCP0: Connection to 10.133.23.17:15269, advertising MSS 1460
112834: May 9 18:00:26.024: TCP0: state was SYNRCVD -> ESTAB [179 -> 10.133.23.17(15269)]
112835: May 9 18:00:26.024: TCB6388CA58 callback, connection queue = 1
112836: May 9 18:00:26.024: TCB6388CA58 accepting 63A095A0 from 10.133.23.17.15269
112837: May 9 18:00:26.024: BGP: 10.133.23.17 passive open
112838: May 9 18:00:26.024: BGP: 10.133.23.17 went from Active to Idle
112839: May 9 18:00:26.024: BGP: 10.133.23.17 went from Idle to Connect
112840: May 9 18:00:26.028: TCP0: RST received, Closing connection
112841: May 9 18:00:26.028: TCP0: state was ESTAB -> CLOSED [179 -> 10.133.23.17(15269)]
112842: May 9 18:00:26.836: BGP: 10.133.23.17 remote close, state CLOSED
112843: May 9 18:00:26.836: BGP: 10.133.23.17 -reset the session
112844: May 9 18:00:27.836: BGP: 10.133.23.17 went from Connect to Idle
112845: May 9 18:00:27.836: BGP: 10.133.23.17 closing
112846: May 9 18:00:27.836: TCB 0x63A095A0 destroyed
112847: May 9 18:00:27.836: BGPNSF state: 10.133.23.17 went from nsf_not_active
to nsf_not_active
112848: May 9 18:00:48.833: BGP: 10.133.23.17 went from Idle to Active
112849: May 9 18:00:48.833: BGP: 10.133.23.17 open active, delay 18155ms
Any help please...
27 Replies 27
jrahm
TCP is acting correctly, so it doesn't appear to be a connectivity issue. Is neighbor authentication configured on this peer? The neighbor is resetting the connection, it appears your router is sending (or not sending) something disagreeable to the neighbor's configuration.
No authrntication is configured.. Beside I did remove all the config other than the just neighbor statment..
Could you see if there any BGP specific message in the log. The session is being reset by the peer and I would like to see if a notification message has been received.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
No thing in the log... And the other peer is getting the same message.. Reset by peer...
Here's debug IP bgp from the other peer
May 5 17:42:05: BGP: 10.133.23.18 went from Idle to Active
May 5 17:42:05: BGP: 10.133.23.18 open active, delay 25886ms
May 5 17:42:12: BGP: 10.133.23.18 went from Active to Idle
May 5 17:42:12: BGPNSF state: 10.133.23.18 went from nsf_not_active to nsf_not_active
May 5 17:42:12: BGP: 10.133.23.18 went from Idle to Active
May 5 17:42:12: BGP: 10.133.23.18 open active, delay 28304ms
May 5 17:42:21: BGP: Applying map to find origin for 10.133.255.12/32
May 5 17:42:31: BGP: 10.133.23.18 passive open
May 5 17:42:31: BGP: 10.133.23.18 went from Active to Idle
May 5 17:42:31: BGP: 10.133.23.18 went from Idle to Connect
May 5 17:42:32: BGP: 10.133.23.18 remote close, state CLOSED
May 5 17:42:32: BGP: 10.133.23.18 -reset the session
May 5 17:42:33: BGP: 10.133.23.18 went from Connect to Idle
May 5 17:42:33: BGP: 10.133.23.18 closing
May 5 17:42:33: BGPNSF state: 10.133.23.18 went from nsf_not_active to nsf_not_active
May 5 17:42:53: BGP: 10.133.23.18 went from Idle to Active
May 5 17:42:53: BGP: 10.133.23.18 open active, delay 16496ms
May 5 17:43:10: BGP: 10.133.23.18 open active, local address 10.133.23.17
May 5 17:43:10: BGP: 10.133.23.18 went from Active to OpenSent
May 5 17:43:10: BGP: 10.133.23.18 sending OPEN, version 4, my as: 64513
May 5 17:43:10: BGP: 10.133.23.18 send message type 1, length (incl. header) 45
May 5 17:43:10: BGP: 10.133.23.18 remote close, state CLOSED
May 5 17:43:10: BGP: 10.133.23.18 -reset the session
May 5 17:43:11: BGP: 10.133.23.18 went from OpenSent to Idle
May 5 17:43:11: BGP: 10.133.23.18 closing
May 5 17:43:11: BGPNSF state: 10.133.23.18 went from nsf_not_active to nsf_not_active
Could you provide us with the configuration from both sides.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
We cleared all the extra config.. What we have now is that
router bgp 64513
network 0.0.0.0
neighbor 10.133.23.18 remote-as 65513
The other peer
router bgp 65513
network 172.16.0.0 mask 255.255.0.0
neighbor 10.133.23.17 remote-as 64513
Nothing fancy in this configuration ;o) Can you do a "sh ip bgp nei 10.133.23.18" and "sh ip bgp nei 10.133.23.17" on the respective routers.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I have a very limited access to the peer router.. So here is sh ip bgp from my router..
XXXXXXXXXX#sh ip bgp nei 10.133.23.17
BGP neighbor is 10.133.23.17, remote AS 64513, external link
BGP version 4, remote router ID 0.0.0.0
BGP state = Active
Last read 00:00:18, hold time is 180, keepalive interval is 60 seconds
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 859 0
Notifications: 0 0
Updates: 0 0
Keepalives: 0 0
Route Refresh: 0 0
Total: 859 0
Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
BGP table version 1547, neighbor version 0
Index 1, Offset 0, Mask 0x2
Incoming update prefix filter list is test
Outgoing update prefix filter list is test
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 0 0
Prefixes Total: 0 0
Implicit Withdraw: 0 0
Explicit Withdraw: 0 0
Used as bestpath: n/a 0
Used as multipath: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 0, min 0
Connections established 0; dropped 0
Last reset never
External BGP neighbor may be up to 255 hops away.
No active TCP connection
What IOS versions are you running on either side? Can you run "deb ip bgp 10.133.23.17" on your side.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I'm running 12.3.3a and he's running 12.3.1a..
the debug did not return any data... And the same at his end as well.. FOr some reason he's not receiving any BGP updates from my end and I'm not receiving any BGP updates from his end.. However the TCP session seems to be fine....
From the info you provided, the TCP session is not up. You can quickly verify that with "sh ip bgp summary" and "sh tcp brief".
I'm kind of surprised that the debug command didn't return any info. How did you run the debug via telnet. If so, did you enter the "term mon" command? After entering the "deb ip bgp nei 10.133.23.17", could you do a "clear ip bgp 10.133.23.17" just to be sure that we will get something out of the debug command.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
This command does not work "deb ip bgp nei 10.133.23.17" so I used "deb ip bgp 10.133.23.17 updates".. And yes I turned on term mon and still sees no thing...
"deb ip bgp 10.133.23.17 updates" won't help in this case. Try "deb ip bgp".
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
