Bonding ISDN pri
allan.wells
Level 3
Level 3
I'm looking for a config for bonding 10 channels on ISDN between two sites.
This will be used as backup and we want 10 channels 640k always and to be up imediately when primary link fails and dials remote
A link or config would be great.
thanks
A
ebreniz
Level 6
Level 6
I don't think this is a good design , because all the channels run on the same wire, So if your physical media fails you can't use your backup too.
