C857W proper bridging between vlan and radio interface
tekha
Level 3
Level 3
Could any one help me out here. I'm totally lost.
I can't get the dhcp server to work, infact I can't even ping the routers LAN IP. However I have a cabled PC on Fast0 and a laptop on the wireless, and they are infact able to ping each other.
Here is the config:
Router#sh run
Building configuration...
Current configuration : 1454 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip dhcp use vrf connected
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
no ip domain lookup
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ssid SOMETHING
vlan 1
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no snmp trap link-status
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip http server
ip http access-class 10
no ip http secure-server
access-list 10 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Router#
Show commands will follow in the next posting.
tekha
Level 3
Level 3
Router#sh dot11 ass
802.11 Client Stations on Dot11Radio0:
SSID [SOMETHING] :
MAC Address IP address Device Name Parent State
0013.ce86.ff7b 0.0.0.0 - - self Assoc
Others: (not related to any ssid)
Router#sh bridge 1
Total of 300 station blocks, 298 free
Codes: P - permanent, S - self
Bridge Group 1:
Address Action Interface Age RX count TX count
0013.ce86.ff7b forward Do0.1 P 101 1
0050.dad9.ff0a forward Vlan1 12 13 1
Router#sh mac-
Destination Address Address Type VLAN Destination Port
0013.ce86.ff7b Dynamic 1 Vlan1
0014.f2e2.61c7 Self 1 Vlan1
0050.dad9.ff0a Dynamic 1 FastEthernet0
Router#sh arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.1.1 - 0014.f2e2.61c7 ARPA BVI1
Router#sh vlan-s
VLAN Name Status Ports
1 default active Fa0, Fa1, Fa2, Fa3
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 1002 1003
1002 fddi 101002 1500 - - - - - 1 1003
1003 tr 101003 1500 1005 0 - - srb 1 1002
1004 fdnet 101004 1500 - - 1 ibm - 0 0
1005 trnet 101005 1500 - - 1 ibm - 0 0
Router#
If there is anything else you need to know, please tell me, because I'm stuck.
Well, well what do you know, apparantly this command "bridge 1 route ip" makes all the difference.
Everything is working as intended.
