CAB-DSU-RJ45 cable
ddufault
I have installed a WIC-1DSU-56K card into a Cisco 1721 router and the card came with a CAB-DSU-RJ45 cable. My telco tells me I require a RJ48S or RJ48C cable to connect to the Frame circuit. I read on a vendor site that the CAB-DSU-RJ45 is equivalent to RJ48S but have been unsuccesul in validating this on Cisco site. Can anyone confirm\refute that the cable I have will work?
geoff.belknap
That cable and any straight ethernet cable will work.
For 56k/64k's you only need pins 1,2,7 and 8.
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/prod_technical_reference09186a00800a8585.html#wp38010
For T1's you only need pins 1,2,4 and 5.
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/prod_technical_reference09186a00800a8585.html#wp38057
Hope this helps,
-Geoff
