An ISP shipped a router and CSU/DSU which included the following configuaration for the s0 interface.
interface Serial0
description WAN
bandwidth 128
ip address 1.1.1.1 255.255.255.252
ip nat outside
load-interval 30
Since this is supposed to be a 256K circuit I asked why the bandwidth setting on the serial interface is set to 128. The response was that it did not matter because the line speed was controlled by the router on the other side.
Sounds kind of fishy to me. Can I get my 256 using the config above? Does the ISPs explanation hold water?
TIA,
Diego
