Cat 4507R Sup4 Redundancy problems
admin_2
Level 3
Level 3
I have 2 catalysts 4507R with sup4 (WS-4515) installed in redundancy mode.
I noticed that it is not always the same sup which is active each time I boot the catalysts.
Does anyone know the way the active is 'elected'?
Is there a way to force on sup to be choosen as the active?
Thanks!
Prashanth Krishnappa
When you power cycle the chassis, the active sup would normally be the sup in slot 1. Somethings I would look for
1)Are you booting from bootflash/flash card?
2)If you have more than one IOS image in the bootflash/flash card of active/standby Sup. Make sure the image you want to boot is the first image in both Sups
3)Boot variables/config register is properly set
bsivasub
Level 4
Level 4
Currently there is no command to make any one of the supervisor active. If I remember correctly, there is plan to make it happen.
If you end up with the sup you don't want active, immediatedly do a "reload" or redundancy force-switchover on the active.
wsitu
I wouldn't be overly concern which sup is active, as long your redundancy works.
