08-25-2005 08:03 PM - edited 03-02-2019 11:49 PM
Good day, folks.
When I plug in a console cable to a Sup 2 engine on a Cat 6509, the screen shows I am in ROM monitor mode (rommon 1> )! And the switch load shot up to 30% instantly. A reboot was necessary by then. Online diagnostics test show the hardware was fine. I using IOS ver 12.1(E3)11b.
Did anyone experience this before?
08-25-2005 10:10 PM
Jason,
It only happens when you plug the console cable ?
When it shows sup in rommon, does all the connectivity come down.
Seems to be some cosmetic issue. I will try to find some more info on this.
regards,
-amit singh
08-26-2005 09:19 PM
Yes, the connectivity did went "dead". And the switch load indicator would reflect "30%" instantly, which is abnormal.
Thanks for your effort.
