02-16-2005 01:25 AM - edited 03-02-2019 09:41 PM
Hi, Does anyone know what the requirments are to run VRF lite on the Cisco 4500 Switch? I have found documentation that says that it is supported but it doesnt indicate what IOS or SUP requirments.
02-16-2005 06:25 AM
It is supported in Sup4/5/2+ from 12.1(20)EW onwards.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_2170.htm#wp432696
But I suggest that you run 12.2(18)EW3
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_5184.htm
02-16-2005 09:35 PM
hi,
thanks for the information, but do you know if it requires a certain feature set of IOS?
